Results 1 to 17 of 17
Thread: "service engine soon"
09-26-2012, 08:21 AM #1
Message comeing out on the dash were the options comes out "service enigine soon" no fault codes at all..and no its not the oil message..just wondering what can trgger this message to com on..I just got back my mail oder tune and is started doing this..
Mods..cai..long headers tube...no cats...
09-26-2012, 09:38 AM #2None Shall Pass
- Jan 2010
- East of Cleveland, Ohio
Black- 99 WS.6 - Modified
Who tuned it?
09-26-2012, 09:46 AM #311 years of bangin gears
- Jan 2009
- North Jersey
At first I was going to suggest checking the OPSU at the back of the intake manifold. But that would trip the "service vehicle soon" light.
09-26-2012, 11:20 AM #4None Shall Pass
- Jan 2010
I'm wondering if the tuner didn't set something properly.
09-26-2012, 11:38 AM #5
09-26-2012, 11:42 AM #6
I got a mail order tune from Nelson performence....I was reading something about. Maybe it being something with 02 sensors??..I'm running long tubes and no cats..but no other messegas comming out..or warning signs..
09-26-2012, 12:34 PM #7James Bond
- Aug 2007
- Texas
did they tune out your rear O2s?
09-26-2012, 05:19 PM #8
09-27-2012, 06:14 AM #9
09-27-2012, 06:16 AM #10
09-28-2012, 04:06 PM #1111 years of bangin gears
- Jan 2009
- North Jersey
You don't get a "beep" warning, do you? If not, then it's not the OPSU.
09-29-2012, 11:34 AM #12
Yea as soon as the sytem is checked...it just start beeping a couple of time with the message..
And another new thing that came up is trouble code p0171...lean on bank 1.
So I'm thinnking that could be triggering the message??
About the code..I'm trying to trouble shoot what exactly needs to be fixed..I used to have an sd tune before and now running a reg..maf on tune..so I'm thinking the mass air flow sensor is not working prperly?? Anyone have any advide I can use..
10-01-2012, 05:08 PM #1311 years of bangin gears
- Jan 2009
- North Jersey
I believe that code is for multiple misfire. I had that code. Check your wires as one could be loose. My issue was my #5 cylinder plug wire had come free from the spark plug. Found that and reconnected it and all is well. Did you check your oil lever and OPSU? You might be leaking from the OPSU. As for the MAF, if you're running the SD tune with the MAF, you could be having an issue, but don't quote me on that as my car still uses the factory MAF. Get back to us as soon as you can.
10-01-2012, 05:50 PM #14
I meant I was running an SD tune before I got the tune from nelsons so right now I'm running maf...I did check the oil pres. But no leaks..still working on checkin each plug now..but to be honest the car is running awsome..I'm getting a lot more mpgs thn before..but I don't light that chk engine light :O...and even my transmission feels better..it used to kinda slip or sty stuck on a gear..now I haven't. Haed an issue since the tune
10-02-2012, 07:07 PM #1511 years of bangin gears
- Jan 2009
- North Jersey
Okay. Let us know what you find.
11-22-2012, 12:31 PM #16Member
- Oct 2012
- ardmore oklahoma
yellow- 2004 pontiac gto
on my gto when the service light comes on, my oil is ready to be changed. I set it to come on at 3500 miles.
11-26-2012, 08:26 PM #17
You are getting better gas mileage because your car is running lean (not using as much fuel as it should be). Hence why you have the P0171 code (System Too Lean (Bank 1)).
I would get it fixed, pronto.
Start with cleaning the MAF sensor with CRC cleaner.
If that doesn't clear the code, check for vacuum leaks downstream of the MAF sensor.
Question: "Service Engine Soon light" Got a P0430 code
By gymrat11 in forum Camaro / SSReplies: 8Last Post: 01-09-2014, 07:42 AM -
Help: Service Engine Soon Light On ???"s
By dickeymoore in forum General HelpReplies: 9Last Post: 07-02-2012, 07:32 AM -
Blinking "Service Engine Soon Light"??
By Tampa T/A in forum Firebird / WS6Replies: 13Last Post: 02-13-2011, 03:23 AM -
Help: "service engine soon"
By Sayed_000 in forum General HelpReplies: 25Last Post: 12-02-2008, 02:31 PM -
Whats the difference between a "Super Charged" and a "Turbo Charged" engine?
By Neil in forum Forced InductionReplies: 13Last Post: 10-25-2007, 04:43 PM
