    Dec 2010
    Madison, WI
    1965 GTO
    With fuel line question
    I am putting in an L99 in my '65 GTO restomod project and need some help with the fuel lines. On my LS1 project, I got the engine with an AN6 mail on the fuel rail, on the L99 it just has a regular steel line like I should just slip on a fuel line and use a hose clamp. My question here is that I like the look, and ease of use, of the AN6 connectors but don't know the best way to transition from the current fuel rail connector to the AN6.
    Also, with the regulator, same kind of question on the input and return lines. I also noticed that the output of the regulator has some kind of funky connector and was wondering what I need to order here. The LS1 I did on my previous project already had something on the regulator that provided a male AN6 connector.
    Also, what size hardline should I run from the tank to the regulator? I am planning on stainless braided line between the regulator and the fuel rail but have to run the hardline to the tank from scratch and need to know what size I should run. Was thinking 3/8 but am not sure.
    Thanks for any thoughts you have on this.
    Retired Outlaw Sum Bitch
    You can get fuel line fittings that allow AN fitting on one end and push on (clamp) on the other. Look around....something like this
    You can get them in Chrome/90 degree/Male/Female...whatever.....
    For your application 3/8" would be correct.
    My first car...1965 GTO.....
    By the way....just outside Madison...is there a bar called Rebels Roost still there?
    Dec 2010
    Madison, WI
    1965 GTO
    Thanks for the help, have some experience with those and planning on that route. What I was wondering about was the special connector on the regulator output side, that looks like some kind of push in connector or something. On my Jeep, this had a AN6 male on the end so that worked out great.
    Sorry, can't help on Rebels Roost, but it sounds interesting.
    Will have to post some shots of the '65 when I get closer. Been doing a frame off, and just got the engine mounted to the chasis this last week. Lots of wiring and plumbing to do then hope to get things fired up this spring.
    On the quick connect fittings.....you can get replacement fittings from AutoZone/PepBoys etc......are they like this?
    http://www.autozone.com/autozone/rep...96b43f8038ecec
    Dec 2010
    Madison, WI
    1965 GTO
    I think that is it exactly. I have the female version on the regulator, and on my LS1 the opposite on the fuel rail.
    A quick related question, if I went with an aftermarket regulator, what pressure range do I want for the LS series? Specifically a L99 in this case. Is this a range between 25-75?
    Mine ( 2004 GTO 408 Stroker motor) runs 62lbs WOT and 58'ish at idle and cruising around.....LS1's run the same....+/- a tad ....
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    I suspect your rail has a quick connect setup. There are several places that sell quick connect to AN adapters like this.
  1. ls1 fuel rail 98-? single fuel line
    By LEADSLED in forum Parts Wanted / Trade
    Last Post: 12-08-2011, 01:50 PM
  2. For Sale: LS1 Fuel Rail Covers with 2 Fuel Line Cutouts - Cut for F-Bo
    By '99 SLP#24 in forum Parts For Sale / Trade
    Last Post: 01-11-2011, 06:24 PM
  3. kinked fuel line while changing fuel filter
    By krese in forum Firebird / WS6
    Last Post: 10-04-2010, 03:02 PM
  4. In-Line Booster Fuel Pump Question?
    By Tman in forum Forced Induction
    Last Post: 10-16-2007, 10:23 AM
  5. Removing fuel supply line from fuel rail
    By GatorSS in forum General Help
    Last Post: 01-02-2007, 05:10 PM
