12-21-2010, 08:40 AM #1Senior Member
- Aug 2007
- Greensboro, NC
Pewter- 2002 Trans Am WS6 M6
Left side of motor is not igniting.
So been chasing this problem for the better part of a week. When driven the cars left side cylinders will not ignite under 2500 rpms or 60 mph. Every time we hook it up to a computer it tells us that we are getting multiple misfires. We have changed the plug wires, spark plugs, checked the coil packs over and they are working fine. We put in a new intake gasket thinking it was pulling air from a leak somewhere and causing the problems. Also pulled and cleaned the injectors. My mechanic is baffled and everyone he has talked to with experience on LS1s has said one of these items were the source but after going over them all we still have the same issue. If any of you guys have any insight we would really appreciate it.
12-21-2010, 08:45 AM #211 years of bangin gears
- Jan 2009
- North Jersey
Are there any loose electrical connections on the left side of the engine? Like maybe a main coil harness? Almost sounds like a bad ground for the coil packs.
12-21-2010, 08:51 AM #3Senior Member
- Aug 2007
- Greensboro, NC
Gone through all the connections and they are good.
12-21-2010, 08:56 AM #4O U 8 1 2
- Nov 1999
- over here...
do you have any friends that can swap out the PCM with to see if your pcm isn't shitting out on you???
12-21-2010, 09:06 AM #5
12-21-2010, 09:21 AM #6O U 8 1 2
- Nov 1999
- over here...
the only other thing i can think of is if you've ever jacked the engine up (maybe to put headers in) that the wires might have been pinched between the firewall and engine...
12-21-2010, 12:10 PM #7
12-21-2010, 12:13 PM #8
12-29-2010, 07:52 AM #9Senior Member
- Aug 2007
- Greensboro, NC
Mechanic called me back finally to go over everything since he wasn't in town when I got the car. Turns out the car had water in the computer.
12-29-2010, 08:33 AM #10
12-29-2010, 10:30 AM #11Senior Member
- Aug 2007
- Greensboro, NC
Good to know will check it when I get off work later.
12-29-2010, 05:11 PM #1211 years of bangin gears
- Jan 2009
- North Jersey
Keep us posted.
(WANTED) 01 WS6 Right and left side rockers
By ViperSniper in forum Parts Wanted / TradeReplies: 1Last Post: 12-09-2009, 08:22 PM -
Burnout stronger on left side?
By silverWS6 in forum General HelpReplies: 6Last Post: 08-04-2009, 10:50 AM -
left side of Y pipe flattened
By Fred H. in forum External EngineReplies: 6Last Post: 05-08-2008, 12:23 PM -
Knocking T/A left side
By Flutesailfish in forum Firebird / WS6Replies: 4Last Post: 04-15-2007, 11:48 AM -
Pass the Dutchie on the left hand side...
By CaptainCaveMan in forum Almost Anything GoesReplies: 4Last Post: 06-20-2006, 06:24 PM
