Thread: Burnout stronger on left side?
08-01-2009, 02:17 PM #1
So i have a pair of nitto 555r drag radials that i use for drag racing... well not anymore cuz they sucked so now i got me some m/t et streets
i cant wait to try em out!!!! Anyyyyyyyyways i was noticing my driver side rear tire is more wasted that my passenger side rear tire... Anybody have any idea why? i only use em for the track, I do have a adjustable panhard bar which i believe is correctly adjusted.. could it be that it isn't correctly adjusted?
08-01-2009, 07:43 PM #2Slow'er'Ass
- Thornton, CO
How many miles on them that you are able to notice a difference in tread?
Are you sure the car is warming up both tires and not just one?
If both are spinning for the warm-up, it probably has an issue with the rear suspension not being aligned properly. This could be the panhard, the LCA's, pinion angle, etc....
08-02-2009, 08:41 AM #3Junior Member
- Aug 2009
- Toledo, OH
Maple Red Metallic- 2000 Pontiac Trans Am M6
I've noticed this on some Fbodies too. A T/A I was looking at had a bit of rubber on the drivers but none on the pax side. The Z I'm looking at currently (and will most likely buy) also had it.
Someone took that one out for a saturday joyride and nobody was the wiser. Just a few flicks of rubber on the passenger side but the point behind the rear wheel on the drivers side had some nice dried rubber flecks all over the fender.
08-04-2009, 01:00 AM #4
08-04-2009, 03:32 AM #5
The right rear pulls up on acceleration. That's why people use the air bag on the right, or the anti roll bar ( drag bar ) to hold the rear even. That's also the reason when the car launches, it pulls the left front, while the right rear squats.
08-04-2009, 09:08 AM #6
08-04-2009, 10:50 AM #7Junior Member
- Aug 2009
- Toledo, OH
Could also explain why high power (even base LS1) apps on the rear ends of some Camaros and Firebirds end up toasting the rears. Almost as if the engine under the right conditions could have TOO much torque.. I could definitely feel the twist for sure when I went off the line in that car.
Left side of motor is not igniting.
By raynor139 in forum General HelpReplies: 11Last Post: 12-29-2010, 05:11 PM -
(WANTED) 01 WS6 Right and left side rockers
By ViperSniper in forum Parts Wanted / TradeReplies: 1Last Post: 12-09-2009, 08:22 PM -
left side of Y pipe flattened
By Fred H. in forum External EngineReplies: 6Last Post: 05-08-2008, 12:23 PM -
Knocking T/A left side
By Flutesailfish in forum Firebird / WS6Replies: 4Last Post: 04-15-2007, 11:48 AM -
Pass the Dutchie on the left hand side...
By CaptainCaveMan in forum Almost Anything GoesReplies: 4Last Post: 06-20-2006, 06:24 PM
