Results 1 to 15 of 15
Thread: Vibration?
    Oct 2009
    pasadena md
    Blog Entries
    2
    2002 SS Camaro
    Vibration?
    Hey I just started having this problem where I am having a vibration infront of the steering wheel. It only happens when I'm stopped starting to move and sometimes when its getting higher in the rpms, doesnt happen when in neutral. Would you guys know what the problem is?
    Retired Outlaw Sum Bitch
    OK....do you mean the dashboard shakes or what? What do you mean "in front of the steering wheel"?
    Do you have a auto or manual?
    What mods if any?
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    Definitely need more info like Sarge stated...
    Some of the more popular things that cause vibration though are:
    - unbalanced/bad tire
    - engine mounts
    - transmission mounts
    - drive shaft out of balance
    Apr 2010
    IN
    +1 with what 35th said
    i had some vibration and my car pulled me all over the road...a simple rotation of the tires and its wayyy better
    Orlando, FL
    Mean Black
    Check your wheels also. i had some bad vibration on the steering and I have a slightly bent wheel. The wheel were also out of balance. Other things to check is the tires itself and their tire pressures. My tires looked okay but they had 20psi in them. Now they are bad.
    Do you have any play on the wheels? If you rotate the tires to the back, does the vibration follows?
    All the stuff that 35th mention could cause vibration too. Check for a bad u-joint at the driveshaft and the tranny mount.
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    I am thinking the same as 35th, but you posted when you're stopped...which makes me ask if you have an aftermarket crank pulley on your car. If so, you might want to look into that as well as some underdrive pulleys will cause a vibration while the car is running but sitting idle.
    Oct 2009
    pasadena md
    Blog Entries
    2
    2002 SS Camaro
    I have everything stock on the car... besides a tranny mount and thats it and it is coming from the engine bay
    Oct 2009
    pasadena md
    Blog Entries
    2
    2002 SS Camaro
    I also have new lifters and its a rebuilt motor so I dont think its coming from them
    North Jersey
    2004 GTO M6
    Even at idle, you get a vibration?
    Oct 2009
    pasadena md
    Blog Entries
    2
    2002 SS Camaro
    It is not as loud at idle but it is faintly there but around 2100 rpms is when it hits it's peak vibration
    I would say motor mounts if at idle and as the RPM goes up the vibration gets worse if you get it when the car is sitting still.
    The vibration is coming from something that is turning or spinning if the vibration gets worse with RPM.
    Perhaps a pulley that is unbalanced, etc.
    Oct 2009
    pasadena md
    Blog Entries
    2
    2002 SS Camaro
    How would you check if the pully was unbalanced?
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    Look at it with the engine running and see if it wobbles or is bent.
    Pittsburgh
    2008 Hummer H3
    "doesnt happen when in neutral"
    6spd- a4? Check torque converter bolts if it's an auto.. Check Pilot bearing if m6..
    another thing to check is the little bump stops that rest on the axles... they dry rot... more than likely you have a bushing or mount that is shot...
  1. vibration
    By jsmith564` in forum General Help
    Last Post: 02-25-2012, 04:50 PM
  2. vibration
    By ron83 in forum Drivetrain
    Last Post: 03-29-2011, 04:01 AM
  3. Help: Bad Vibration
    By 2001TransAm in forum Drivetrain
    Last Post: 11-24-2009, 06:42 AM
  4. vibration
    By shadowsnkx in forum Drivetrain
    Last Post: 07-31-2008, 06:14 PM
  5. vibration
    By JROBINSON1016 in forum Internal Engine
    Last Post: 03-20-2007, 05:23 PM
