Thread: Plug and go?
12-17-2010, 06:32 PM #1I Drive A 95'
- Aug 2009
- Granbury, Texas
01' Firebird Pewter- 98' Trans Am Black
Plug and go?
I have a pair of 6 1/2 in. infinity speakers on hand right now, and im wondering if i can just take put my factor backseat speakers, splice the wire from the factory plug, and use the factory wiring to crimp the connection to the infinitys, and just screw them back in, and have them work fine? will i need any additional stuff?
12-24-2010, 09:04 PM #2I Drive A 95'
- Aug 2009
- Granbury, Texas
just installed these speakers myself, kinda looks retarded, and im worried about them catching in fire!
oh well, i need to tweak them because they sound worse then stock :*(
12-24-2010, 09:32 PM #3Senior Member
- Feb 2010
- north bay california
Black- 00 camaro ss M6 #6695
Do you have stock radio or aftermarket?
02 tahoe Z71 blacked out
98 z28 red m6 sold
07 zx6r ninja flat/black sold
08 zx6r ninja sold
12-25-2010, 06:06 AM #4I Drive A 95'
- Aug 2009
- Granbury, Texas
stock
12-25-2010, 07:49 AM #5
Did you phase them properly?
12-25-2010, 07:54 AM #6
12-25-2010, 08:00 AM #7
+ to + and - to - is what he's talking about as far as phasing them.
12-25-2010, 08:17 AM #8
12-25-2010, 09:08 AM #9
Many factory speakers are not marked positive (+) and negative (-) so you need to determine correct phasing. Easiest thing to do is disconnect the factory speaker (make sure to note the color code on the connector if the plug is reversible) and then with a short piece of wire and a AA battery test it. Start by holding the wire to the negative side of the battery and touch the other end of the wire to one of the terminals. With the wire in place then touch the positive end of the battery to the other terminal and watch the speaker cone.
You will hear a "pop" and the speaker cone will move as the connection is made. If the cone thrusts outward then you have properly identified the (+) and (-) terminals. If the speaker cone sucks in then you know you have it backwards. Change terminals and it should then thrust outward. It is important to properly phase speakers as they can essentially cancel each other out and will generally sound terrible otherwise.
Best Plug wires and plug gap
By Intrepidman in forum General HelpReplies: 12Last Post: 12-30-2008, 09:30 AM -
plug gap
By twozs in forum General HelpReplies: 6Last Post: 04-17-2008, 03:49 AM -
TR6 plug gap
By Mr. Luos in forum Internal EngineReplies: 3Last Post: 10-30-2006, 10:38 AM -
What is this plug for?
By RoadKillBunny in forum General HelpReplies: 0Last Post: 04-01-2006, 04:11 PM -
Spark plug wire and plug!
By RYDER661 in forum General HelpReplies: 2Last Post: 03-13-2006, 09:01 PM
