Results 1 to 20 of 24
    Member crossbredfoxbody's Avatar
    First In Flight
    83 mustang coupe
    L33 5.3 arp 799 heads heat sink coils BAD @ss fuel system
    Fuel system 650.00 obo with out fuel cell
    cleveland ohio
    48 (100%)
    trans am 00 ws6
    1998 camaro ss vert
    you need to list each item with a price.
    First In Flight
    83 mustang coupe
    L33 std bore aluminum block new cam bearings 200.00 with crank and rods sensors and bolts
    __________________ Heat sink coils 100 shipped Block comes with rods pistons oil pan crank
    First In Flight
    83 mustang coupe
    Member JRENIGAR's Avatar
    Oct 2009
    arkansas
    1 (100%)
    99 camaro
    What ratio are the rockers???
    First In Flight
    83 mustang coupe
    Rockers sold
    First In Flight
    83 mustang coupe
    First In Flight
    83 mustang coupe
    head studs sold
    First In Flight
    83 mustang coupe
    TTT
    Oct 2009
    arkansas
    1 (100%)
    99 camaro
    Just to clarify, are the 799 heads exactly like the 243's or ls6 heads?? Same cc chambers and such??? How many miles on em? Have you had them checked at a shop for warpage, cracks? Any milling done to em? ect... Thanks.
    Oct 2009
    arkansas
    1 (100%)
    99 camaro
    Quote Originally Posted by crossbredfoxbody View Post
    They were pulled by the book. and engine ran fine had 100,000 miles on it. they are the same as the 243's I have a set of valve springs with titanium retainers that are good up to 650 lift that can go with them for 300 Dyno time only on springs and retainers.
    Are they the double springs or like the comp 918's??? Wonder how much shipping would be to 72335?
    Oct 2009
    arkansas
    1 (100%)
    99 camaro
    Double springs 40.00 shipping The springs and retainers cost me over 200.00
    Do you know the diff between the two as far as what ones are needed for a particular cam setup. What brand and part # are they? Im gonna look up the specs on em and see if they will work with the comp cam Im lookin at.
    First In Flight
    83 mustang coupe
    I don't have the part number they were bought for a 236/242 580/890 lift cam and they are stock diameter. I still have the cam too.
    First In Flight
    83 mustang coupe
    First In Flight
    83 mustang coupe
    First In Flight
    83 mustang coupe
    Springs pistons main studs and pistons timing set sold
    First In Flight
    83 mustang coupe
    TTT
    First In Flight
    83 mustang coupe
    TTT
    First In Flight
    83 mustang coupe
    Fuel system
    460+ Gallons per hour
    Fuel system 800.00 obo with fuel cell
    Adjustable up to 43 P.S.I.
    (Approx. 35 PSI max @ 12 Volts)
    (Approx. 43 PSI max @ 16 Volts)
    External -8 bypass valve (adjustable)
    Alcohol compatible
    Works with 12 or 16 volts
    7 Vane impeller
    -12 AN boss O-ring inlet & outlet ports
    Continuous duty
    Known as the "Standard" in the industry, this pump has all of the same capabilities as the PE 4450 Combo, minus the filter. Good for up to 2000 Horsepower, this pump is built to the same specifications as it's Combo brother. Same motor, same internals, same quality and attention to detail. The pump is hard anodized in our traditional colors of blue/gold (shown). Additional color combinations available for a nominal charge. Matching HI-FLO fittings available in blue, black, gold and purple.
    First In Flight
    83 mustang coupe
    Pump was 405 and has never been used 18ft 10an 9ft 6an 4ft 12an 3ft 8an most of the fittings are new. 2 aeromotive regulators and 1 BG regulator
  1. Mast 305cc heads, 4500 EFI Carys Intake, T&D Rockers
    By cam02ss in forum Parts For Sale / Trade
    Last Post: 10-27-2014, 04:03 PM
  2. Help: Studs
    By SMWS6TA in forum General Help
    Last Post: 08-14-2014, 11:30 AM
  3. Help: New studs.....
    By 98TransAmWs-6 in forum Wheels and Tires
    Last Post: 04-17-2012, 03:16 AM
  4. Suggestions? Cams/heads/rockers
    By freni32 in forum Internal Engine
    Last Post: 12-24-2006, 09:08 AM
  5. Wheel Studs>>Help
    By mikriman1 in forum Wheels and Tires
    Last Post: 04-23-2006, 05:13 PM
