Results 1 to 15 of 15
    I Drive A 95' AfterYou's Avatar
    Aug 2009
    Granbury, Texas
    01' Firebird Pewter
    98' Trans Am Black
    Manually using your Antenna?
    Is there a way to Manually put down a radio Antenna on the Firebird?
    Its constantly on enzyte, and is always up
    Is there a way I can manually put it down to about half way without breaking it? Ive taken everything out to see the motor "spare tire"
    but I dont see any kind of crank to do so with...
    Any suggestions?
    Jul 2009
    North of the Motorcity
    Custom Swirly Black
    2001 WS6 M6
    It doesn't work I'm assuming. Hook a test light to it and see if your getting power back there.
    If you aren't, you could try and put 12v to it and try to get it down.
    Aug 2009
    Granbury, Texas
    01' Firebird Pewter
    98' Trans Am Black
    Im getting power to it, because when i turn the power of the car "on" it makes the sound of the antenna moving, but doesnt. So im assuming its a stripped gear?
    Junior Member jrpimp00's Avatar
    Fayetteville, NC
    Why dont you replace it? I just did mine with one off of ebay for about $13
    Aug 2009
    Granbury, Texas
    01' Firebird Pewter
    98' Trans Am Black
    What all did you replace? Im not much of a electrical kind of person, and how hard was the install? and did you replace it with another retractable one?
    Fayetteville, NC
    the actual antenna wich has the cable already attached. IT was simple and it came with step by step instructions. Took me about 30 mins total. and thats with cleaning out 8 inches of water that was in my trunk.
    Try a search on ebay for a replacement antenna
    Here is a search I jsut did:
    http://shop.ebay.com/i.html?_nkw=fir...=p3286.c0.m359
    Aug 2009
    Granbury, Texas
    01' Firebird Pewter
    98' Trans Am Black
    so i dont suppose there is a way to force it down, and not be able to use it again? because i just use my ipod/phone and play music off that, so my radio is never on, just a biotchh to have to worry about people bending it all the dang time
    Veteran Blackbird WS6's Avatar
    van down by the river
    Quote Originally Posted by AfterYou View Post
    i dont really know BUT i think its gear driven...you might have to take the motor apart and take the insides out so it can drop the ant?? just an idea
    OR delete it and send me all the parts so i can fix mine lol
    Aug 2009
    Granbury, Texas
    01' Firebird Pewter
    98' Trans Am Black
    Quote Originally Posted by Blackbird-WS6 View Post
    haha, ive seen somebody post a picture on here with his completely taken off, and shaved, looks really nice, but i dont think ill be doing that
    phoenix
    04 2500 4x4 crew cab
    I just ripped mine out, and there is a plastic cable that winds into the motor, and mine was snapped.
    Senior Member 98maro's Avatar
    Feb 2010
    north bay california
    00 camaro ss M6 #6695
    that happns on my ss.. i just put in down.. then it works fin for a while..
    but mine doesnt make the sound it just stays up...
    02 tahoe Z71 blacked out
    98 z28 red m6 sold
    07 zx6r ninja flat/black sold
    08 zx6r ninja sold
    Member jetaws6's Avatar
    Apr 2009
    Fallston, Maryland
    1998 Trans Am Ws6
    you can just push it down gently and eventually it will go all the way down. Thats what I did with mine and then just unplugged it because I only listen to cd's in that car
    Pittsburgh
    2008 Hummer H3
    Try some lubricant on a shop cloth and then wipe the shaft of the antenna when it's fully in the up position but don't soak it.. You only need a film of oil.. I used hoppes gun oil on my old Grand Prix with the same issue.. Worked like a charm.. However if the drive is damaged it may need to be replaced.. Or you can switch out to a Camaro non-retractable and never worry about it again..
    Tulsa,OK
    Quick Silver
    2002 Z06
    I also tried some lubricant on mine when it did not go all the way down. Usually worked fine for a couple months until it washed off. I tried several different kinds silicon based etc..
    Over the years I have seen more fix themselves then get fixed by me
    Camaro Owners Click Here
    Firebird Owners Click Here
    www.AutoTrix.net
    Bird Rehab Center ThunderChicken's Avatar
    Dec 2010
    Mebane, NC
    I need to do this with my 95. Not a problem with the 98 because it has no mast. So we'll see what happens with that one.
  1. Convert power antenna to fixed antenna
    By Red 99 T/A in forum Firebird / WS6
    Last Post: 01-24-2009, 10:40 AM
  2. manually shifting a4
    By Bigck4 in forum Automatic Transmission
    Last Post: 08-24-2008, 03:19 PM
  3. manually shifting an auto
    By LT1 > LS1 in forum Drivetrain
    Last Post: 08-03-2008, 05:47 PM
  4. How to manually close power windows?
    By MagicMan in forum General Help
    Last Post: 08-17-2006, 05:00 PM
  5. Replies: 2
    Last Post: 05-04-2006, 01:48 PM
