Results 1 to 3 of 3
    CVB
    Guest
    What is the process of resetting the ses light manually?
    I don't want to go to Auto Zone again, my 00 WS6 keeps throwing a clutch switch circuit problem code, and ifI reset it it doesn't come back for months. But I can't remember which fuse needs pulled and for how long etc.
    Thanks for he help!!
    Senior Member
    Jacksonville, FL
    Did you find the answer? You can reset the PCM but it'll also reset all the readiness tests and make the idle a little grumpy until it relearns:
    Turn key on, don't start car. Pull PCM BATT and PCM IGN fuses in engine compartment. Wait 5-10 min. Turn ignition off. Replace fuses.
    Commerce Ga
    Black, Blue
    07 TBSS, 07 GSXR1000
    Quote Originally Posted by 2001NBMZ28
    Couldn't have said it better myself.
  1. Resetting ABS light w/o trac
    By Whamhammer in forum General Help
    Last Post: 04-07-2015, 04:56 PM
  2. Manually using your Antenna?
    By AfterYou in forum General Help
    Last Post: 12-12-2010, 09:07 AM
  3. resetting oil change light in dash
    By Darkrider02 in forum Camaro / SS
    Last Post: 10-03-2009, 06:14 PM
  4. manually shifting a4
    By Bigck4 in forum Automatic Transmission
    Last Post: 08-24-2008, 03:19 PM
  5. Resetting the Security Light
    By whiteflash in forum Stereo and Electronics
    Last Post: 03-19-2007, 11:08 AM
