Thread: brake caliper boots
12-07-2010, 10:00 AM #1
brake caliper boots
Hi guys while I replaced my hubs i noticed that my front caliper boots around the pistons are torn. Is this something i should replace? Is it critical to put new ones in? I use ceramic pads so i don't have alot of dust. But im not sure about water and the elements. thanks.
12-07-2010, 10:20 AM #2
Should be replaced imo. Dirt, road grime and moisture will eventually work its way in there and cause problems. You can sometimes fake a repair with Permatex Black Silicone if it is just a small tear.
12-07-2010, 10:32 AM #3
i dont think I can fake it. is a pretty big chunk that came off. I will order them and replce them. Thanks.
12-07-2010, 10:56 AM #4
yeah, replace them. It will let dirt and water in there and freeze those up at some point.
12-07-2010, 12:19 PM #5
12-13-2010, 11:06 AM #6
i was looking at the boots today. Do i need to remove the piston to get the boot off? or Can i just pry them out? thanks.
12-13-2010, 02:59 PM #711 years of bangin gears
- Jan 2009
- North Jersey
I don't think you have to pull the piston out, but I could be wrong. I have never dealt with torn piston boots before. I think they just pull out with a pick tool. I know most shops would suggest remanufactured calipers. Your choice though.
Question: Replacement Parking Brake Boots
By jcws6 in forum General HelpReplies: 5Last Post: 10-02-2014, 03:56 PM -
By pajeff02 in forum General HelpReplies: 4Last Post: 01-12-2010, 09:32 AM -
Shifter & E-brake boots for A4s?
By SiggyZ in forum Appearance SectionReplies: 6Last Post: 02-17-2007, 06:06 PM -
Shifter and E-brake boots for A4s?
By SiggyZ in forum Appearance SectionReplies: 1Last Post: 12-19-2006, 06:27 AM
