    Hemi Destroyer 98-LS1's Avatar
    Knoxvegas, Vol country Tennessee
    Sebring Silver
    98 Z-28 camaro
    oil pan gasket replacement on a 98 LS1 camaro
    I got quoted over $450.00 through the dealership just to replace the oil pan gasket on my Z-28! I ain't paying that, it's barely wet around the front under the harmonic balancer on the pan. Is this something I can do myself without pulling the motor out? Looks like the pan would slide out the rear being the crankshaft is placed more inside the motor than older style small blocks or would it hit? I can't stand having any kinds of oil leaks but before I attempt this I was looking for some tips from someone who knows more than me about these things, thanks!
    redls1bird
    Guest
    from what i remember it looking like, its really tight. i would think that you would have to disconnect the motor mounts and jack the engine up a little to get enough clearance. im not sure if that would do it though.
    TX
    Gold
    98 Trans Am
    You will need to drop the k member to get the clearance you need.
    near St. Louis
    navy blue
    2002 Z-28 Camaro M6
    Oil pans are almost always a PITA,they take more clearance than it looks due to the oil pump pickup being so close to the bottom of the pan. My advise-live with the barely wet leak,it's meaningless. Clean it off every once in a while with some brake clean,or pony up the bucks for someone else to do it.
    WI
    Blog Entries
    1
    09 EclipseGT 75 Chevy 4x4
    2001 Trans-Am 13 F-XT
    A couple bottles of the good old leak stopper should plug up that leak for a couple of bucks! (Not to mention everything else too)
    Sebring Silver
    98 Z-28 camaro
    I'll just deal with it for now and if it gets worse then I'll pay the dealer to fix it, thanks but I don't feel like going through all that trouble just to fix a small leak. Thanks again
    Commerce Ga
    Black, Blue
    07 TBSS, 07 GSXR1000
    You can jack up the motor and get enough room to drop the pan down some, but you wanty be able to pull it out unless you drop the k-member.
    Sebring Silver
    98 Z-28 camaro
    Thanks, Big D, been a while since I've hollered at ya'll. Work has been a pain in the ass this past month but I'm still trying to get out of drill in April for the Year One show.
    Commerce Ga
    Black, Blue
    Hope you can make it down.
  1. Valve cover gasket replacement
    By Axhammer in forum Firebird / WS6
    Last Post: 01-26-2014, 05:39 AM
  2. Oil Pan Gasket Replacement
    By Fastdaddy in forum External Engine
    Last Post: 10-24-2009, 07:50 PM
  3. Oil Pan Gasket Replacement
    By Wesman in forum External Engine
    Last Post: 09-24-2007, 09:53 PM
  4. Valve Cover Gasket Replacement
    By wnmech in forum External Engine
    Last Post: 03-27-2007, 04:26 PM
  5. 3.8 V6 valve cover gasket replacement
    By gearyr in forum External Engine
    Last Post: 01-03-2006, 06:36 PM
