Thread: Oil Pan Gasket Replacement
10-24-2009, 05:32 PM #1
Need some quick help on situation. I have the heads, intake, manifolds, timing cover, off the block and I want/need to replace oil pan gasket. I will be replacing Oil Pump also, and I know you need to drop the pan a little just to do that. Can I remove bolts in Mounts and pickup engine enough to clear pan removal. Do I have to unfasten anything else besides mounts to get motor to raise up on a engine lift? Thanks for the response..
10-24-2009, 05:39 PM #2
yeah the 3 bolts on each side to lower the a frame. Been there done that. Not that bad of a job, take your time.
10-24-2009, 05:41 PM #3
Why do you want to replace the gasket ? They are pretty good - sounds like unecessary work.
04 C5 A4 Torch Red - sold
2009 CTS4 Ice Black - sold
2013 1500 Silverado Z71 - sold
02 Z/28 M6 Onyx Black All Options - Sold
2014 Caddy CTS4 - DD
2016 Silverado 2500HD
2020 Caddy XT6
2020 2SS Vert
10-24-2009, 06:55 PM #4
Really don't want to, but I feel that the leak puddle is growing. I have read all over LS1 that most deal with this issue, and there are several fixes. If it's just leaking at the joint of the crank cover and pan lip than can't I just lay in some RTV while I have it dropped down a bit for the oil pump replacement? Speaking of...I do have to drop the pan a little to get the pump off right?
10-24-2009, 07:50 PM #5
Valve cover gasket replacement
By Axhammer in forum Firebird / WS6Replies: 11Last Post: 01-26-2014, 05:39 AM -
By Wesman in forum External EngineReplies: 11Last Post: 09-24-2007, 09:53 PM -
Valve Cover Gasket Replacement
By wnmech in forum External EngineReplies: 1Last Post: 03-27-2007, 04:26 PM -
oil pan gasket replacement on a 98 LS1 camaro
By 98-LS1 in forum General HelpReplies: 8Last Post: 03-14-2006, 09:22 AM -
3.8 V6 valve cover gasket replacement
By gearyr in forum External EngineReplies: 0Last Post: 01-03-2006, 06:36 PM
