Results 1 to 10 of 10
Thread: popping out of gear....
11-23-2010, 09:07 PM #1
my 2nd gear either pops out of gear or it wont go into gear.......witch ever it feels like doing lol this happens 80% of the time
i haven't looked into it more BUT what would it be??
all other gears are fine...
11-23-2010, 10:23 PM #2
11-24-2010, 08:25 AM #3
11-24-2010, 09:19 AM #4
11-24-2010, 05:44 PM #5Senior Member
- Apr 2008
- Madison, WI
could also be a bent shift fork but the doesn't happen very often with the 1-2 shift fork. Could also be the shift fork pads worn off or a shifter problem. Basically its either a bad synchro problem or the synchro isn't be shifted all the way into gear (ie bent fork, worn fork pads, shifter problem).
What kind of shifter do you have?
11-24-2010, 07:23 PM #6
11-25-2010, 05:21 AM #7Senior Member
- Apr 2008
- Madison, WI
Any possibility the shifter stops need to be adjusted?
11-25-2010, 08:50 AM #8
11-25-2010, 08:53 AM #9Senior Member
- Apr 2008
- Madison, WI
yes...but sometimes things aren't as black and white as you'd expect. IDK, its worth a shot. Otherwise, yes there is something wrong inside the transmission.
11-25-2010, 08:58 AM #10
Question: Tranny popping out of Fourth gear...
By RAWS6 in forum Manual TransmissionReplies: 4Last Post: 06-04-2008, 12:55 PM -
6th gear popping out? HELP!
By SteelmanLS1 in forum Manual TransmissionReplies: 15Last Post: 08-02-2007, 08:12 AM -
2002 Camaro ss a4 Help! redlines a gear then changes a gear from a roll please read!
By hmorris7000 in forum Camaro / SSReplies: 24Last Post: 06-05-2007, 03:01 PM -
By hmorris7000 in forum General HelpReplies: 9Last Post: 06-01-2007, 05:18 PM -
Popping out of gear?
By INeedLS1 in forum Manual TransmissionReplies: 13Last Post: 02-17-2007, 05:59 AM
