Thread: 5th gear issue
    Junior Member black2kSS's Avatar
    Nov 2010
    cheektowaga, ny
    2000 camaro ss
    5th gear issue
    im hoping that someone here has had this problem, while driving at thruway speed i shifted into 5th gear and experienced a vibration that made a loud drone and resonated through the whole car. i have heard that the gear can get play in it and cause this. car only has 25k on it so it seems wierd but hey stuff happens. any help would be great
    Indianapolis
    2000 WS6 6spd Hooker LT
    Never heard of this. Anyone else? If it was truly a 5th gear issue, it would most likely show up any time you are in 5th. Otherwise it could be a resonance issue with a particular RPM/MPH.
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    Yeah thats a tough one. I agree with TooFast. Sounds like you may have to have a pro go on a road test with you.
    Nov 2010
    cheektowaga, ny
    2000 camaro ss
    i have found only one forum talking about this issue, can't remember where tho. they seem to think the actual gear is not pressed on the shaft tight enough which causes it to have a small amount of play in it, which causes the vibration. i have the ability to rebuild it myself but was hoping someone on here had heard of, or actually seen it themselves.
  1. 1st gear issue on 04
    By wonderboy in forum GTO
    Last Post: 07-21-2010, 04:54 PM
  2. Having an issue with Reverse gear (6sp)
    By nasmith7 in forum Manual Transmission
    Last Post: 03-15-2010, 12:02 AM
  3. Headlight help. Not the normal gear issue.
    By MistrCreazil in forum Firebird / WS6
    Last Post: 08-06-2009, 08:05 AM
  4. 6th gear issue..
    By shlby123 in forum Firebird / WS6
    Last Post: 03-18-2007, 03:57 PM
  5. Power Issue In Third Gear
    By q1234567890 in forum Forced Induction
    Last Post: 04-26-2006, 02:59 PM
