    Nov 2010
    League City Tx.
    99 SS Camaro
    Engine almost dies
    I got a 99 SS Camaro that will every now and then surge. What I mean is it will be idling smoothly then have a big miss and almost die. When it does this all the gauges will jump around like you start the car. Then it will throw a Engine Light but continue to run OK. Any ideas!
    Member dav-02ws6-m6's Avatar
    Mar 2010
    VA
    2002 trans am ws6
    it could be a miss fire but not sure. you could take it to an auto parts so that they scan the computer.
    Dirty throttle body or IAC valve, out of adjustment IAC valve, vacuum leak, or an electrical issue... just a few guesses.
    Nov 2010
    League City Tx.
    99 SS Camaro
    Engine almost dies
    Thanks for the responses. After reading some other threads it looks like I may have an electrical issue. I have had the alternator go out twice and replaced the battery. I had a PS leak that caused both of the issues on the alternator and have corrected that. I am going to check all the connections especially since it sits and the battery is usually down every time I get ready to drive it.
    Member TA98's Avatar
    Mar 2009
    Maryland
    grounds. and IAC
  1. Last WWI veteran dies
    By Schmalgar in forum Almost Anything Goes
    Last Post: 03-05-2011, 10:09 AM
  2. Lt1 suddenly dies, help please
    By dirttrax in forum General Help
    Last Post: 03-06-2010, 11:00 AM
  3. 02 Z/28 dies when engine warms up.
    By Danger731 in forum General Help
    Last Post: 01-03-2010, 05:37 PM
  4. engine misfires then dies, then runs fine....
    By DemonSpeed in forum General Help
    Last Post: 06-24-2009, 03:14 AM
  5. engine dies when alternator is connected
    By RAT454 in forum General Help
    Last Post: 09-04-2006, 10:31 AM
