Results 1 to 20 of 44
12-18-2009, 07:01 PM #1
02 Z/28 dies when engine warms up.
This has been going on for months. The car starts and runs strong. As soon as it gets to operating temperature it shuts down. I thought a fuel pump issue so I replaced the pump. Car started fine, ran strong until it got to operating temperature then just shut down. any ideas ?
12-18-2009, 07:43 PM #2
I had a friend who had similar problems. I'm not mechanic, nor expert but I thought he said something about changing his coil packs and the problem went away.
12-18-2009, 07:50 PM #3
Here's another idea. I had a Grand Am that did that back in 92. That took a crank sensor. It used to shut off after about 15 minutes of running.
12-18-2009, 08:27 PM #4
Will it start up again?
12-18-2009, 09:05 PM #5
12-20-2009, 01:36 PM #6Senior Member
- Feb 2006
- Orange County, NY
You could just start throwing parts at it or bring it to someone who can run it on a scanner or data log it. That will help identify the problem faster.
12-20-2009, 01:56 PM #7
yeah the simplest cure failed, I needed to upgrade the pump so I was hoping ....
04 C5 A4 Torch Red - sold
2009 CTS4 Ice Black - sold
2013 1500 Silverado Z71 - sold
02 Z/28 M6 Onyx Black All Options - Sold
2014 Caddy CTS4 - DD
2016 Silverado 2500HD
2020 Caddy XT6
2020 2SS Vert
12-20-2009, 02:35 PM #8
Yeah, this sounds like one for the scanner. It sounds like the expansion of the block might be causing a problem with the sensors but you don't want to be chasing this one. Take it to a dealer or someone with a scanner and let them warm it up and see what goes away or see if it has logged any errors.
12-20-2009, 02:37 PM #911 years of bangin gears
- Jan 2009
- North Jersey
My car did this but only after I shut it off when warm. When refired, it would run for 5 seconds then shut down and would run fine after another startup. Had the car tuned and all is fine now. Any mods to OPs?
12-20-2009, 02:38 PM #10Awaiting Activation
- Oct 2007
- NC
SOM- 1998 T.A.
Maybe it is a MAF issue. When it's cold you are in open loop and once it warms up it switches over to closed loop and that seems to be when your problem occurs.... You need a better tool than just a code reader you need to look at it with something like a Tech II or Snap on scan tool. They can do a lot more than just read codes.....
12-21-2009, 08:33 AM #11
12-21-2009, 02:36 PM #12Awaiting Activation
- Oct 2007
- NC
SOM- 1998 T.A.
Haha!!! I feel for the guy but yeah it could keep him from chasing his tail... I am lucky.... I know a guy from hanging at the track that will look at mine for no $$$ with a Snap on and it will do what a Tech II will.....
Edit...HP tuners, EFI Live etc...will work too....
12-21-2009, 09:08 PM #13
12-21-2009, 09:13 PM #14
Get HPT on it and see what it is doing
12-30-2009, 11:09 AM #15
Well no codes, everything from what I can tell seems fine. MAF sends a signal as does the o2 sensors.
12-30-2009, 11:15 AM #16Blown, Stroked, & Sprayed
- Aug 1999
- No Where
Were you able to get it scanned?
12-30-2009, 09:09 PM #17
12-31-2009, 05:33 AM #18Awaiting Activation
- Oct 2007
- NC
SOM- 1998 T.A.
Make sure you post up what you find out. This is interesting......
12-31-2009, 06:09 AM #19
12-31-2009, 06:50 AM #20
Engine almost dies
By Horns23 in forum External EngineReplies: 4Last Post: 11-13-2010, 12:56 PM -
Oil pressure high...75 at start & until warms up
By Z28er in forum General HelpReplies: 13Last Post: 04-07-2010, 12:53 PM -
engine misfires then dies, then runs fine....
By DemonSpeed in forum General HelpReplies: 4Last Post: 06-24-2009, 03:14 AM -
Misfires when engine warms up... help!!!
By Shnukemz in forum LT1Replies: 5Last Post: 10-05-2006, 03:27 PM -
engine dies when alternator is connected
By RAT454 in forum General HelpReplies: 0Last Post: 09-04-2006, 10:31 AM
