    Import Killer SLP00blueSS's Avatar
    MIchigan
    header bolts?!?!?!
    I know it has probably been covered before but i did a search and got no answers.........So i'am going to be putting long tube headers on my car and want to know if i should use the locking grade 8 bolts or the bolts provided in the pacesetter kit?!?!?!
    Pueblo, Colorado
    1998 Pontiac Trans Am
    I used the ones that came with the headers and they work fine but there wouldnt be anything wrong getting locking bolts.
    Bragg NC
    Met. Sunset Orange
    01 SS
    I used the ones that came with the pacesetter kit, so far no problems
    J
    MIchigan
    ok, great!!! did you guys use any lock tight or anti-seize??
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    you could reuse the factory bolts. they are interference bolts. meaning easy to go in. but "feels" like they are crossthreaded coming out.
  1. Question: header bolts
    By jodmari in forum General Help
    Last Post: 10-21-2014, 06:15 PM
  2. Help: Header bolts
    By Lunatikgixxer in forum External Engine
    Last Post: 05-07-2010, 02:03 PM
  3. Stage 8 Header Bolts
    By BirdCountry02 in forum External Engine
    Last Post: 06-30-2009, 10:29 PM
  4. Header bolts
    By Bender10 in forum External Engine
    Last Post: 01-06-2008, 06:23 PM
  5. Header bolts
    By 87Iroc-Z in forum External Engine
    Last Post: 05-07-2006, 04:22 PM
