Results 1 to 20 of 33
Thread: manual to Automatic swap
11-04-2010, 07:13 PM #1
i want to swap from a manual 6speed to a 4l60e
reason being my t56s been built already and i believe i twisted splines on the input shaft.
i want to go automatic due to i run over 100+passes a year in it and im looking to be more consistant and have less driveline shock.
Im pretty sure i know just about what i need to convert over but anyone with any Good info about this id really appreicate Thanks
11-04-2010, 07:30 PM #2Exalted Cyclops
- Feb 2007
- San Diego, CA
I don't know what is required to swap but I also realize that an A4 is hands down better in the 1/4 mile over an M6. That is unless you're Ronnie Sox (if you don't know then look it up)...
You'll find the info you need here eventually.67 Camaro: K-K + 797-z (look it up), 454/Th400/4.10 12-bolt = 6mpg, PS/PDB/PW tilt, tach, gauges...
Carbon footprint? CLOWN SHOE!
11-04-2010, 09:46 PM #3Member
- Oct 2009
- Philadelphia
Sunset metallic orange- '01 Camaro SS
Yea I'm in the same boat too dude my tranny is going soon and my buddy keeps tellin me to go auto but I love m6 so it's tough decision for me. I'm seriously considering it, but I don't know what to do or what I have to get as far as auto goes. B/c as of this moment I'm rebuilding my t56 to a stage 2 cuz I figured while it's getting worked on(keep throwing the stick out of rev.) to just upgrade everything to stage 2 so hopefully there will be no more probs. when I put more power to it. I mean it did last me 55k without a problem at all but I guess I won't more consistent times at the track to. My favorite one is the one were you have to manually put it into 1/2/&3 w/ a 4th OD I just don't know what it's called
Sent from my iPhone using Tapatalk
The sound of your piss hitting the urinal.......yea it sounds feminine!
11-05-2010, 03:07 AM #4
11-06-2010, 01:52 PM #5Im not that old and I know whe he is, heard stories about the old Sox & Martin mopars.My guess is that only old fogies like us are going to know who he is.
op you'll need the trans which is obvious, auto cross member maybe and prolly the electronics.
11-06-2010, 11:22 PM #6
11-22-2010, 10:25 PM #7Junior Member
- Aug 2009
- Clovis, California
Sunset Orange- 2002 WS6 Trans Am
A random shot in the dark, for an m6 to a4 swap, i assume requires; pedal assembly, the whole center console assembly, a plug that'll work as the neutral safety switch (unless you want to run a bypass), removing the slave(idk if you can remove and just use the master, idk how those work yet), A4 Tranny mount, the transmission/torque converter, either a tranny cooler or if your radiator permits tranny lines, flex plate, the cable that connects the transmission to the center console assembly (sorry i forget names of items, but i know what they look like and their purpose). Then after all said n done some computer playing/tuning and i think it is all done. "I think"
11-24-2010, 06:24 PM #8Exalted Cyclops
- Feb 2007
- San Diego, CA
For those of you not in the know (apparently not the majority of the repliers to this thread - Thank God!) Ronnie Sox = Mr 4-speed. He could shift an A833 (if you don't know look it up) better than any slushbox (if you still don't know look that up too) ever made.
To my age group he was a racing GOD!
11-25-2010, 07:29 AM #9
12-22-2010, 07:06 PM #10
12-22-2010, 07:08 PM #11
almost in
12-22-2010, 07:14 PM #12Exalted Cyclops
- Feb 2007
- San Diego, CA
Th400?
One of my buddies has a TH400 with a trans brake in his turbo'd 00 Z28. Mid 9 second passes at better than 140mph....
12-22-2010, 07:15 PM #13
th350
12-22-2010, 07:17 PM #14
12-22-2010, 07:21 PM #15
yes sir
12-22-2010, 07:24 PM #16Exalted Cyclops
- Feb 2007
- San Diego, CA
I had a TH350 that I rebuilt 3 times over a 20+ year life that I had in 6 different cars so I should've recognized it. Chalk it up to "Old Timers" disease (LOL)...
12-23-2010, 07:17 PM #17
12-23-2010, 07:38 PM #18
yep sure is
01-02-2011, 04:29 PM #19
01-02-2011, 05:08 PM #20Member
- Oct 2009
- Philadelphia
Automatic to Manual Swap
By bobh13908 in forum Manual TransmissionReplies: 1Last Post: 10-06-2011, 05:37 PM -
manual to an automatic
By Badinfluenzebrew in forum DrivetrainReplies: 8Last Post: 10-05-2011, 11:51 AM -
Automatic or Manual
By chiller2484 in forum Almost Anything GoesReplies: 66Last Post: 09-03-2009, 08:36 AM -
Manual/Automatic
By NewLS1 in forum Firebird / WS6Replies: 72Last Post: 04-29-2007, 07:07 AM -
Automatic to Manual 6 Speed Transmission Swap - Possible? - Impossible?
By Pyromaniacal in forum LT1Replies: 2Last Post: 07-25-2006, 06:56 PM
