11-04-2010, 01:16 PM #1
with or without traction control??
I have a 98 Ta and im lookig into getting braided stainess lines. But they offer two kinds. those with and those without traction control? does it matter or not?
11-04-2010, 03:42 PM #2
I am not 100% on this, but the traction control equipped cars may have dual circuit rear brakes while the non-traction control cars do not. Someone please verify this... it is an educated guess.
11-04-2010, 04:34 PM #3Senior Member
- Jan 2010
- texas
silver- 2000 formula
do you mean.....3 channel or 4 channel ABS?
11-04-2010, 06:04 PM #4
11-04-2010, 11:16 PM #5
so 3 channel is Non Traction control and 4 Channel has traction control? and which woud I have? and how would i be able to tell?
11-05-2010, 02:59 AM #6
4 channel has sensors that mount at the ends of each axle in the backing plate. 3 channel has a sensor on top of the differential, and nothing out at the axle ends. In the pic, you can see the black wire loom running along the back of the axle tubes -- that is the harness for the sensors (Note: rear is a 12 bolt and will look a bit different than stock):
11-13-2010, 01:51 PM #7
11-23-2010, 09:03 AM #8
after doing my rear brakes i do believe i have a 3 channel rear end. Which would hav eme believe that i dont have traction control in the rear. I would also guess this since i don t have the traction control switch in car
cruise control with traction control
By basballny2 in forum General HelpReplies: 12Last Post: 06-16-2010, 11:57 PM -
traction control
By racer426 in forum GTOReplies: 8Last Post: 12-16-2008, 07:04 PM -
traction control
By jordanvb in forum General HelpReplies: 15Last Post: 12-12-2008, 01:48 PM -
abs and traction control
By davidz28guy in forum CorvetteReplies: 7Last Post: 08-12-2006, 08:28 PM -
Traction Control
By daryl.l in forum Firebird / WS6Replies: 4Last Post: 03-05-2006, 01:05 PM
