Results 1 to 2 of 2
Thread: clutch packs sticking?
10-26-2010, 05:05 AM #1Junior Member
- Oct 2010
- louisiana
silver TA...red GTO- 2002 trans-am...2004 GTO
so...ive got a stock 2002 trans-am ive had the car for about 6 years and have had the transmision rebuilt once 4 years ago and put new axel shafts and rear wheel bearings in it about 2 years ago...now its starting to give me more problems...
what its doing
running in a straight line i have no problems and it makes no sounds no matter what speed im going...but when i make a turn (the tighter the turn the worse it is) its more of a clunking sound than a grinding and it feels like the inside tire is jumping like it would running over say a rumble strip and if its a hard say 10mph turn you can hear the inside tire squeal everynow and then like its not turning like it should...could this be the clutch packs in the lsd sticking and if so how hard is it to fix
thanks for any and all help
10-26-2010, 06:06 PM #2Senior Member
- Apr 2008
- Madison, WI
yes the problem sounds like its in the rear end. But the stock diff for 2002 is the Torsen posi. It doesn't have clutches. Its a gear driven posi. If its going bad, there isn't much you can do but replace the posi itself. But you could try a fluid change and add a bottle of LSD additive in there.
Replacing clutch packs?
By Dove1b in forum Automatic TransmissionReplies: 3Last Post: 01-04-2013, 05:00 AM -
Clutch pedal sticking 98 TA
By nochey in forum Firebird / WS6Replies: 5Last Post: 04-24-2012, 11:14 AM -
By DrMilhouse in forum General HelpReplies: 3Last Post: 02-10-2008, 04:47 AM -
Clutch Sticking to the Floor??
By Roastem in forum Manual TransmissionReplies: 2Last Post: 06-10-2006, 12:25 PM -
For those with clutch sticking problems...
By swimster144 in forum Manual TransmissionReplies: 3Last Post: 03-16-2006, 10:19 PM
