    Oct 2010
    Houma,La.
    Charging system issues?
    Quote Originally Posted by Nukkl Dragger View Post
    30 miles from home I noticed that the volt gauge was just above the orange lines, when I got home it was on 13 and charging, so went to get some pizza it was still charging, next morning it was in the orange paint and must have been around 8 volts, I took the Alternator off and checked it out it was given it was running great (NAPA checked it out) now it won't start because the battery is drained.
    Did I miss anything?
    I have the same symtoms and I do have a leaking power steering pump ,is it to late for my alternator or can I stop the leak and the alternator still be good?
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    Quote Originally Posted by Darcey99LS1 View Post
    probably too late if you are already having charging system issues
    Oct 2010
    Houma,La.
    The shop I bought the alternator from says my battery is to small and I need more cranking amps for a 200 amp alternator. And I looked at the alternator and no power steering Fluid on it. The alternator charges good when the engine is cold , only when the engine gets at normal operationing temp. it starts dropping the charge at a idle.
    Madison, WI
    2001 Silverado Z71
    ^^^I don't think it would matter too much what size battery you put in a car. Alternator charging is kind of "on demand" thing. You could put a tiny 12 volt jetski battery in there and it should still charge like normal. Why the 200 amp alternator?
    Madison, WI
    2001 Silverado Z71
    BTW, I have now moved this discussion to its own thread
  1. Help: 2000 lS1 (Charging system issue/question)
    By TerribleTed in forum General Help
    Last Post: 01-16-2011, 08:27 AM
  2. charging system help
    By tattmick in forum General Help
    Last Post: 01-24-2008, 04:17 PM
  3. 99 Trans Am Battery/Charging System Problem
    By 1999TransAmWS6 in forum Firebird / WS6
    Last Post: 10-13-2007, 05:06 PM
  4. charging system problems
    By blky2kz in forum External Engine
    Last Post: 09-12-2006, 06:24 PM
