Thread: Rear End issues
10-16-2010, 04:23 AM #1
Rear End issues
i have a problem with my rear end it hops wen i acclerate it in reverse the car is a 6 speed if any only knows whats causing this let me know thanks!
10-16-2010, 07:56 AM #2Member
- Jun 2009
- coon rapids, MN
red- 2000TA
how many miles on the car?wore out torque arm mount,or bad lca bushings,weak rear springs?mite need to upgrade some suspension parts.
10-16-2010, 10:13 AM #3Junior Member
- Oct 2009
- US
- 2002 Camaro
10-16-2010, 11:50 AM #4
You need to explain a bit more - what circumstances are you talking about - when you are backing out of the drive or a parking space, when you are trying to back up hill, or when you are fooling around and accelerating too hard?
10-22-2010, 07:52 PM #5
I had the same issue right away when I put lowering springs on the rear of the car. I replaced them with stocks one and problem was gone. Maybe you need new springs and or shocks. I also upgraded my Panhard bar and LCA's. That helped tremendously with wheel hop.
Like the guys said don't be too hard on reverse.
10-23-2010, 07:59 AM #6
reverse is not for racing lol
Help: rear end alignment issues
By godless-phoenix in forum Suspension and HandlingReplies: 43Last Post: 12-02-2011, 04:57 PM -
Help: Rear hatch issues
By HOBS in forum General HelpReplies: 19Last Post: 04-16-2011, 11:58 AM -
rear end issues
By wanna_lS1 in forum DrivetrainReplies: 2Last Post: 07-23-2008, 02:03 AM -
Rear alignment issues after removing rear spring isolaters, adj trac bar fix it?
By anestech* in forum Suspension and HandlingReplies: 1Last Post: 06-19-2007, 08:06 PM -
having issues in my rear ;) pls help!
By ninobrn99 in forum Suspension and HandlingReplies: 3Last Post: 12-06-2005, 10:01 PM
