Thread: Wiring Nightmare
10-05-2010, 05:19 PM #1
Wiring Nightmare
I just bought a 1998 WS6 that is extremly modified. All the original wiring is still there and in place. Most everything no needed for drag racing is gone, example, wipers, abs, a/c ect. I started pulling much of it out of the guides and following it. I want to remove all that is not used or connected. Every thing needed on the car is working well. I would like to pull and follow end to end but its looking a bit impossible unless motor and intieror is totally pulled out. My question is would I run in to trouble later if I just take what I can get for now cut it there and cap or silicone ends to prevent sparks from live wires? And then when I do pull the motor go ahead and finish it up. Thanks guys
10-05-2010, 05:24 PM #2
I think you would benefit from the tool that I have. My dad gave it to me, and he used it for cable and phone lines. I think its called a soundphone. You clip a lead on the wire you want to chase down, and then use the wand to identify where it is. It is extremely sensitive, and i used it to rewire the stereo in my car. It would tell you where every wire in the car is run. I dont know if this helps you, but that is what I would use.
10-05-2010, 05:26 PM #3
Thanks I will try to find one
10-05-2010, 06:27 PM #4
if any one else ever been in this situation what did you do?
BBK Nightmare
By Pappy in forum Parts ReviewReplies: 2Last Post: 03-21-2016, 10:19 PM -
Nightmare
By 1998 T/A in forum Firebird / WS6Replies: 2Last Post: 10-06-2008, 02:44 PM -
Lt1 To Ls1 wiring nightmare! poops!
By XcamaroZ06X in forum Camaro / SSReplies: 3Last Post: 06-11-2008, 05:00 PM -
How do i wire two seperate front tweeters with no factory wiring or wiring from deck?
By Mike Hawk in forum Stereo and ElectronicsReplies: 1Last Post: 11-16-2007, 09:41 AM -
Best Buy NIGHTMARE!
By MikeSomething in forum Stereo and ElectronicsReplies: 4Last Post: 03-08-2006, 12:28 PM
