Results 1 to 3 of 3
Thread: Clacking rear end
03-09-2006, 04:27 PM #1Junior Member
- Mar 2006
- san antonio, hell
black- 1999 trans am
Clacking rear end
Hey fellas -
I recently bought a '99 T/A with the Torsen II rear end, and aside from the usual F-body squeaking coming from the rear, she "clacks" at around 20 to 30 mph. I checked the U-joints, no rotational play there - but you can turn the driveshaft (with the trans in park) about 10 or 15 degrees of play. When shifting from park to reverse, there's a clack, and when shifting from reverse to drive there's a clack. Most noticeable is when I'm coasting at around 20 to 30 mph - after letting off the gas, it repeatedly clacks and then stops after a while. I strongly suspect that my rear end needs rebuilt - or does it? This is my first rearwheel drive car, as I've been too poor and only had fronts while longing for an F-body.
Any help is greatly appreciated. If it does need rebuilt, any leads for rebuild kits?
03-10-2006, 03:09 PM #2Junior Member
- Jan 2006
- Northern California
black- 2001 Trans Am
sounds similar to my problem
I often get clunking sounds, most notably in gentle driving around 15-30 mph, mostly if I let off the gas or change gears (often one clunk, sometimes multiple clunks, then stops). It seems to happen most when in neutral or the clutch depressed, and when the car's weight is right on the edge of shifting from back to front or vice versa.
I haven't investigated the cause yet. It doesn't feel terribly like any tranny mount failure I've had before, but close enough it might be. But if that gets ruled out I'm afraid for my bank account...
sectari
2001 t/a, non-ws6 M6. all black. all stock so far
03-10-2006, 09:57 PM #3Junior Member
- Mar 2006
- san antonio, hell
Hmm...
Interesting - I hadn't considered the tranny mounts as a source. I'll get under her tomorrow and shake her some and see if that isn't it. But it's coming from the rear on mine, so I doubt (hopefully) that it's the tranny mounts in my specific case.
Help: clacking noise
By Dakois in forum General HelpReplies: 2Last Post: 09-18-2008, 10:15 PM -
clacking sound
By tarrrron510 in forum General HelpReplies: 23Last Post: 08-08-2007, 05:38 AM -
Rear alignment is off after Koni/!= rear isolator lowering, car pulls to right, specs
By anestech* in forum Suspension and HandlingReplies: 13Last Post: 07-08-2007, 09:42 AM -
Rear alignment issues after removing rear spring isolaters, adj trac bar fix it?
By anestech* in forum Suspension and HandlingReplies: 1Last Post: 06-19-2007, 07:06 PM -
Randy's Rear End Shop Get's Punked (Prank) - Woman looking for a bigger rear!
By powermelissa in forum Multimedia SectionReplies: 0Last Post: 05-25-2007, 10:37 AM
