Results 1 to 16 of 16
Thread: Need some input PLEASE
09-19-2010, 02:35 PM #1
Need a little help, when I shut down my car it makes kind of a slight air compression sound that stops after bout 7-8 seconds, kind of a mild hissing some where around the engine. WTF is that? I did also notice I have a slight oil leak that started about a week ago. Could the two problems be connected? I really dont need this crap I hope its not a big deal, cause I just recently had a hospital trip with no health insurance and owe a couple thousand, im stressed to the max, any help would be great thanks - Jason
btw I ment to put INPUT* IN THE SUBJECT TITLELast edited by Cutlass; 09-19-2010 at 05:47 PM.
09-19-2010, 05:49 PM #2Senior Member
- Apr 2008
- Madison, WI
Fixed your title for you there.
Could the hissing be the A/C? The pressure has to equalize from the high side to the low side after the AC is turned off. It'll hiss as it equalizes
09-19-2010, 07:53 PM #3Senior Member
- Apr 2010
- Alabama
It's the AC like Cutlass said the pressure has to equalize but also check the compressor and make sure that it's not leaking because that will make it hiss too.
09-20-2010, 01:15 AM #4
09-20-2010, 10:11 AM #5
Thanks alot guys, my air was turned on the defrost and was on low, thats probably why I did'nt notice it on. I turned it off and no more hiss
. Need a little more advise though, I think my front oil pan gasket is leaking and I also wonder generally how much that would cost to fix at an auto shop, just a ball park estimate would be great. Would it be wise for me to fix that before I store it next month or could it wait? Cause I dont want all the oil leaked out of my car when I take it out in 6-7 months. And FYI the leak is'nt to bad, some days after I drive it she does'nt leak anything after a few days, but other times after a few days there will be a penny size drop. Kinda weird how it dont leak sometimes after sitting a few days and sometimes it does. Thanks -Jason
09-20-2010, 11:29 AM #6Senior Member
- Apr 2010
- Alabama
I wouldn't pay anyone to do that. Do it yourself. I don't think it would be harmful to wait as long as its not that bad(and you said it wasn't). But there also would not be any harm in doing that before you store it so you have peace of mind when you store it that the leak is fixed that and you don't come back and there is a lot of oil on the floor.
09-20-2010, 03:11 PM #7
If it is the oil pan gasket it will not leak if parked, except residual oil that may have leaked out when driving.
09-20-2010, 04:06 PM #8
Yeah, I'd like to but my wrenching skills are limited, and yeah money wise i'd like to wait next season to fix it, but the peace of mind over the winter would make me really happy to...I called a guy today and he said it would be like $360 or so bucks
I really gotta learn to do some of this shit my self.
09-20-2010, 04:09 PM #9
Hmm, interesting that might be the reason why its so random when I find a spot. I'll look under the car before I take a drive and SOMETIMES nothing will be there, but I come home AFTER the drive i'll look under it a little while later and theres a small oil drip there..., Thanks
09-20-2010, 04:40 PM #10Senior Member
- Apr 2010
- Alabama
Did the guy say what exactly is wrong? I could prolly explain to you exactly how to fix it.
09-20-2010, 05:42 PM #11
09-21-2010, 10:35 AM #12Spaz is My Mentor
sure it isn't the front seal?
09-21-2010, 10:55 AM #13Senior Member
- Apr 2010
- Alabama
Isn't there a gasket in the drain plug too? Could it be that?
09-21-2010, 10:56 AM #14Spaz is My Mentor
no gasket...
09-21-2010, 04:43 PM #15Senior Member
- Apr 2008
- Madison, WI
Yes there is some sort of seal or gasket on the drain plug. When I first got my car, the oil drain plug was leaking because the seal was missing.
09-21-2010, 04:55 PM #16
It's most likely leaking where the timing cover meets the oil pan. Replace the timing cover gasket and run a bead of silicone gasket maker across the bottom of the timing cover. Would make a good winter project. Follow the instructions here, just skip the removing of the cam and valve springs etc. http://www.ls1howto.com/index.php?article=23
Question: To sum it all up!!!! Need input
By Project LS1 in forum Camaro / SSReplies: 11Last Post: 11-02-2010, 10:21 PM -
i need some input
By zeetwentyeight in forum Stereo and ElectronicsReplies: 12Last Post: 02-23-2010, 05:07 PM -
input shaft input
By Ramairgod84 in forum DrivetrainReplies: 0Last Post: 08-01-2009, 03:54 PM -
Need input
By biga0206 in forum LT1Replies: 6Last Post: 01-11-2008, 04:57 AM -
I need your input.
By 2001somws6 in forum Appearance SectionReplies: 42Last Post: 04-18-2007, 04:48 AM
