Results 1 to 13 of 13
    Member zeetwentyeight's Avatar
    Aug 2009
    A, A
    1998 Camaro Z28
    i need some input
    K so i got my stealth enclosure, amp and sub today.
    I need an idea of where to mount my amp, I don't want any wires showing and even the amp if possible let me know thanks
    Jul 2009
    North of the Motorcity
    Custom Swirly Black
    2001 WS6 M6
    Which stealth enclosure is it?
    Member SuperSport346's Avatar
    Nov 2009
    West Michigan
    2002 Camaro SS
    Typically it is put on the rear wall or over the axle. I personally am working on mine this week, but I want to install it directly across from where the sub will be. I have yet to see this done, but I'm going to figure out a way to make mine work
    Jul 2009
    Custom Swirly Black
    2001 WS6 M6
    Quote Originally Posted by SuperSport346 View Post
    If your stealth enclosure is going where the stock cd changer would be (driver side) I'd pull the spare and hide it over there. Really easy to hide wires that way.
    Aug 2009
    A, A
    1998 Camaro Z28
    i was thinking where the spare tires goes but there isn't really any good spot that you can mount it
    Quote Originally Posted by KMdef9 View Post
    The opening on the driver side
    Jul 2009
    Custom Swirly Black
    2001 WS6 M6
    People have had to make brackets, I guess it all depends on how big (size, not power) your amp is and how good you are at fabrication. Every case is alittle different.
    I suggest there because it's the best way to ensure you dont see any wires.
    Aug 2009
    A, A
    1998 Camaro Z28
    It is just a 300 watt
    Nov 2009
    West Michigan
    2002 Camaro SS
    I'm actually going to mount it on the panel. I'm going to have to do some cutting, and add some support, but that's what I want to do.
    TJEA Retirement Home Dr.Crash's Avatar
    Feb 2006
    U. S And A Greatest country in all of world
    Stock
    2002 Camaro
    Quote Originally Posted by zeetwentyeight View Post
    This is where i put mine. i pulled the spare out and cut a MDF board to fit in there. I mounted both of my amps to the board and ran the wires under the carpet.
    Aug 2009
    A, A
    1998 Camaro Z28
    Quote Originally Posted by Dr.Crash View Post
    Thats what im thinking of doin
    Nov 2008
    Holiday,FL
    Green
    1997 Camaro Z-28
    Me 2 It is a great place for that stuff. Out of site, out of the minds of those who want to take it from you. I used a thick card board to make a template and then traced it on to a thin peice of MDF. Dilled one hole in the spare bracket and used another hole on the inner fender with nothing in it for another bolt and then used small ruber and metal stands on the amp to mount it with an air gap. and stay off the bolt I used to mount the board. Use ruber to spacers on any rub points and you have a nice hidden quiet place for all the electronic goodies.
    Feb 2006
    Orange County, NY
    always dirty
    2013 Ram 2014 Caddy ATS
    Quote Originally Posted by JaycenK View Post
    Do you have a pic? Seems like a great spot to mount a single amp easily.
    Aug 2009
    A, A
    1998 Camaro Z28
    well i mounted mine with no cutting or fabricating and it looks pretty good to if anyone is interested ill post some pics
  1. Question: To sum it all up!!!! Need input
    By Project LS1 in forum Camaro / SS
    Last Post: 11-02-2010, 10:21 PM
  2. Need some input PLEASE
    By 1 RedHot TransAm in forum General Help
    Last Post: 09-21-2010, 04:55 PM
  3. input shaft input
    By Ramairgod84 in forum Drivetrain
    Last Post: 08-01-2009, 03:54 PM
  4. Need input
    By biga0206 in forum LT1
    Last Post: 01-11-2008, 04:57 AM
  5. I need your input.
    By 2001somws6 in forum Appearance Section
    Last Post: 04-18-2007, 04:48 AM
