    TerribleTed TerribleTed's Avatar
    California-Sacramento-Roseville
    2000 Chevy Camaro Z28
    Radiator Hose is Swelling up-???
    So I hear no boiling over sounds,,and I dont show a high temp indication on my gauges,,
    But damn it,,I drive it a few miles,,,came home,,popped the hood for an oil change out,,and noticed that the uper radiator hose (the one that has the PS cooler in it) was swelling around where the clamp goes,,
    I was able to open my radiator cap and it did not explode h20 out,,just some pressure release happened,,,
    So what might cause this,,
    The hose just being old,,which it has no signs of that (no cracks or bad color),,
    or is it the t-stat,,,
    Any ideas,,,
    Help,,,
    Blown, Stroked, & Sprayed
    Ed Blown Vert's Avatar
    Aug 1999
    No Where
    383 Procharged & N20 Vert
    Could be the hose or the cap.
    Georgia
    red black
    98Z28
    Maybe a 10yr old hose....., might not look bad. But do you want to wait for failure to change. The swelling is a heads up. I would change it and cap also if it has not been done. You could pressure test it but changing those items is what I would recommend.
    Bragg NC
    Met. Sunset Orange
    01 SS
    If the hose is soft its time to replace, chances are its your rad cap causes the boiling over
    J
    Member bberretta's Avatar
    Aug 2009
    Memphis, TN
    Bright Red
    2000 TA Firehawk 0041/742
    Look at the end of the hose- are the cloth threads in there wet or stained with antifreeze?
  1. Hose from radiator to throttle body
    By Matto4785 in forum General Help
    Last Post: 05-27-2013, 05:26 PM
  2. Question: Upper Radiator hose diameter in '02 TA
    By dgoett in forum General Help
    Last Post: 11-19-2011, 03:25 PM
  3. Radiator hose thing question
    By 408WS6 in forum External Engine
    Last Post: 10-15-2009, 06:58 AM
  4. Upper Radiator Hose blew
    By bberretta in forum Firebird / WS6
    Last Post: 09-20-2009, 08:21 PM
  5. Lower Radiator hose
    By madelife in forum General Help
    Last Post: 08-19-2007, 01:57 PM
