Results 1 to 10 of 10
Thread: Cutout install question...
09-05-2010, 07:56 AM #1Senior Member
- Apr 2007
- Newport, RI
Navy Blue Metallic- '00 Formy A4
I did a search, but I didn't find any info specific to this.
I just bought a QTP 3" manual cutout. I want to intall it in the I pipe, as far back as possible.
Now to install it, can I just cut a section out of the I pipe, and slip the ends of the stock exhaust into the cutout and secure it with clamps?
Every pic I see of cutouts, they're always welded. Shops around here charge a fortune for stuff like that, I'd rather not have to go that route.
So anyone ever just clamp one in?
Thanks!
09-05-2010, 04:43 PM #2rice,its what's fo dinner
- Jan 2010
- Arlington,Texas
Silver/Black- 00' z28-R.I.P 00' WS6 M6
I don't see why you couldn't accomplish the same thing with clamps as long as the I/O have matching diameters. The only thing I can think of going wrong with something like that is if the clamps weren't tight enough and the side of the cutout with the open plate rotates pointing down because of the fact it's slightly heavier thus scraping the ground.
09-05-2010, 05:46 PM #3
I was not impressed with the pipe that came with our DMH cutout -- so I decided to take a different approach as well: http://www.ls1.com/forums/showthread.php?t=137873
09-06-2010, 07:40 AM #4Member
- Jan 2006
- houston
Navy Blue- ls1 trans am
My understanding is the clamps will most likely leak, which wouldnt matter if the cutout was open. When you want to close it it will probably leak some. Surely it can't be that expensive for 2 welds? The 2 clamps may cost half of the cost 2 welds. I believe I paid 35$ to have it cut and welded, but may not be the case where you live.
09-07-2010, 08:10 AM #5
I just got mine welded into my I-pipe. They wanted 100 bucks, but I talked them down to 60
09-07-2010, 10:11 AM #6Senior Member
- Apr 2007
- Newport, RI
See this is what I'm afraid of. After the cost of the cutout, I'm looking at at least 100 bucks total. Too much just to have a loud exhaust IMO.
Maybe I ought to return the cutout, and have a Borla style (cutout after the axle, where the pipe curves toward the muffler) one made instead. It'll probably sound better inside the car, and I can't see it costing any more than 100 bucks.
09-07-2010, 10:22 AM #7
Call up every place in the phone book and see what they say first.
09-08-2010, 05:40 AM #8
The shop I called first said 50 bucks to weld it in, but when I went there in the morning, they were busy and said it would be an all day wait. You could call around and find a small shop that isn't busy to do it for cheap, mine was stainless and they said it was harder to weld stainless steel.
09-08-2010, 09:42 AM #9Member
- Jan 2006
- houston
usually the cutout is the cheap alternative to a catback system, which will run you a couple hundred bucks, or even welding a muffler will cost you more. Most places charge by the weld and a cutout only has 2 welds. With a cat back you can do it yourself and use clamps. I have had my cutout for 9 years now and I love the sound. I call it the poor mans Borla since that system now runs somewhere in the 700-800 for the catback. You may try the clamps and down the line have it welded. You will not be dissapointed by the sound. I have had guys with flowmasters, borlas, corsas, and magnaflow make comments about how they like the way the cutout sounds and you have the option to cap it for inspection ect.
09-08-2010, 02:43 PM #10
My cutout was welded in for $40.
I suggest keep calling around, tell them what price you need it done for, and if they need business they will do it. It is a 20 minute job for a professional exhaust shop.
code p1133 after cutout install
By TransAm11973 in forum General HelpReplies: 11Last Post: 12-22-2011, 06:02 PM -
Fabricated cutout install w/ pics.
By pajeff02 in forum External EngineReplies: 29Last Post: 03-09-2011, 12:52 PM -
QTP Electric Cutout Install/Issues
By muteki in forum External EngineReplies: 2Last Post: 11-17-2009, 01:39 AM -
DMH Cutout for Borla Adjustable Install
By Tickwomp in forum General HelpReplies: 3Last Post: 01-14-2009, 07:04 AM -
electric cutout install help!
By Z28LS1 in forum External EngineReplies: 3Last Post: 07-10-2007, 04:50 PM
