Thread: electric cutout install help!
07-09-2007, 02:55 PM #1
hey guys, i just bought a bandlandz electric cutout. it says in the instructions, "You can run it to a switched fuse in the fuse panel located on the drivers side dashboard." I have one positive wire and a ground wire. How do i run it to the switched fuse? what is a switched fuse?... Also, is the firewall a good place to ground a wire? If not, where should i on a 99 Camaro. Thanks for any input!
07-09-2007, 03:46 PM #2Senior Member
- Jul 2005
- Jacksonville, FL
I've installed a QTP and DMH switch - in both cases I used a "switched" power source (extended and ran the red wire to the radio fuse under the carpet). Switched means power is off when the key is turned off, lighted switch goes off when opening the door in the case of QTP. For ground I used the black wire coming off the cig lighter.
07-09-2007, 03:51 PM #3
Where is that radio wire located? And im guessing i just cut that, tie the wires together and put tape around it.. right? Or could i just somehow run it to a fuse in the fuse box?... sorry im terrible with electical stuff..
07-10-2007, 04:50 PM #4
in the fuse box, you'll have a couple of single ports that are empty. look for the one that's labeled IGN. that is your switched ignition. i used a make spade connector on the end of the wire to get it plugged in. i put the ground wire to the little 10mm bolt where the center console bolts to the dash on the driver's side.
here's pics of the install.
http://www.stealthram.com/qtpcutout.htmlCold Air Intake, Muffler Delete, Vinci High Performance Dual Valve Springs, Hardened Pushrods, Yella Terra 1.85 Rockers, Some Hydropdipped Stuff, Strut Tower Brace, Some SS Badges, boost/vacuum gauge, fuel pressure gauge, some checkered stripes, drilled/slotted rotors, ZL1addons Stealth wickerbill, Ruxifey LED side markers
Electric Cutout?
By natews6 in forum External EngineReplies: 24Last Post: 04-28-2010, 06:03 AM -
QTP Electric Cutout Install/Issues
By muteki in forum External EngineReplies: 2Last Post: 11-17-2009, 01:39 AM -
best electric cutout?
By bluefields88 in forum External EngineReplies: 61Last Post: 11-19-2008, 05:11 AM -
WTB Electric Cutout!!
By L3THAL_Z28 in forum Parts Wanted / TradeReplies: 0Last Post: 09-20-2007, 03:23 PM -
QTP Electric cutout
By Parkerinc in forum Parts ReviewReplies: 6Last Post: 09-28-2005, 10:30 AM
