    Jul 2009
    Philly
    2000 NBM SS
    Torque Spec sheet
    I was browsing this forum a while ago and stumbled upon a tread or link to a bunch of torque specs for different bolts on 4th gen camaros. Can anybody link me to it? Search yielded no results, thus this post.
    Thanks
    molecularmann
    USA
    Velocity Yellow
    2008 Corvette Z06
    Application
    Specification
    Metric
    English
    A/C Belt Tensioner Bolt
    25 N·m
    18 lb ft
    A/C Compressor and Condenser Hose Bolt (at Accumulator)
    16 N·m
    12 lb ft
    A/C Compressor and Condenser Hose Bolt (at Compressor)
    33 N·m
    24 lb ft
    A/C Compressor Bolts
    50 N·m
    37 lb ft
    A/C Compressor Bracket Bolts
    50 N·m
    37 lb ft
    Accelerator Control Cable Bracket Nut
    10 N·m
    89 lb in
    Air Conditioning (A/C) Belt Idler Pulley Bolt
    50 N·m
    37 lb ft
    Air Injection Reaction (AIR) Pipe-to-Exhaust Manifold Bolts
    20 N·m
    15 lb ft
    Battery Positive Cable Nut (at Generator Output Stud)
    22 N·m
    16 lb ft
    Brake Pipe Fitting
    15 N·m
    11 lb ft
    Camshaft Position (CMP) Sensor Bolt
    25 N·m
    18 lb ft
    Camshaft Retainer Bolt
    25 N·m
    18 lb ft
    Camshaft Sprocket Bolt
    35 N·m
    26 lb ft
    Catalytic Converter Nut
    25 N·m
    18 lb ft
    Clutch Pressure Plate Bolt (In Sequence and Evenly Over 3 Increments)
    70 N·m
    52 lb ft
    Connecting Rod Bolts - First Pass
    20 N·m
    15 lb ft
    Connecting Rod Bolts - Final Pass
    85 degrees
    Coolant Temperature Gauge Sensor
    20 N·m
    15 lb ft
    Crankshaft Balancer Bolt - Installation Pass-to Ensure the Balancer is Completely Installed
    330 N·m
    240 lb ft
    Crankshaft Balancer Bolt - First Pass-Install a NEW Bolt After the Installation Pass and Tighten as Described in the First and Final Passes
    50 N·m
    37 lb ft
    Crankshaft Balancer Bolt - Final Pass
    140 degrees
    Crankshaft Bearing Cap Bolts - Inner Bolts - First Pass in Sequence
    20 N·m
    15 lb ft
    Crankshaft Bearing Cap Bolts - Inner Bolts - Final Pass in Sequence
    80 degrees
    Crankshaft Bearing Cap Side Bolts
    25 N·m
    18 lb ft
    Crankshaft Bearing Cap Studs - Outer Studs - First Pass in Sequence
    20 N·m
    15 lb ft
    Crankshaft Bearing Cap Studs - Outer Studs - Final Pass in Sequence
    51 degrees
    Crankshaft Oil Deflector Nuts
    25 N·m
    18 lb ft
    Crankshaft Position (CKP) Sensor Bolt
    25 N·m
    18 lb ft
    Crossmember Bolt (Lower)
    145 N·m
    107 lb ft
    Crossmember Bolt (Upper)
    125 N·m
    92 lb ft
    Cylinder Head Bolts (First Pass all M11 Bolts in Sequence)
    30 N·m
    22 lb ft
    Cylinder Head Bolts (Second Pass all M11 Bolts in Sequence)
    90 degrees
    Cylinder Head Bolts (Final Pass all M11 Bolts in Sequence-Excluding the Medium Length Bolts at the Front and Rear of Each Cylinder Head)
    90 degrees
    Cylinder Head Bolts (Final Pass M11 Medium Length Bolts at the Front and Rear of Each Cylinder Head in Sequence)
    50 degrees
    Cylinder Head Bolts (M8 Inner Bolts in Sequence)
    30 N·m
    22 lb ft
    Cylinder Head Coolant Plug
    20 N·m
    15 lb ft
    Drive Belt Idler Pulley Bolt
    50 N·m
    37 lb ft
    Drive Belt Tensioner Bolt
    50 N·m
    37 lb ft
    End Link Nut
    23 N·m
    17 lb ft
    Engine Block Coolant Drain Plugs
    60 N·m
    44 lb ft
    Engine Block Heater
    40 N·m
    30 lb ft
    Engine Block Oil Gallery Plugs
    60 N·m
    44 lb ft
    Engine Coolant Air Bleed Pipe Bolts and Studs
    12 N·m
    106 lb in
    Engine Flywheel Bolt (First Pass)
    20 N·m
    15 lb ft
    Engine Flywheel Bolt (Second Pass)
    50 N·m
    37 lb ft
    Engine Flywheel Bolt (Final Pass)
    100 N·m
    74 lb ft
    Engine Front Cover Bolts
    25 N·m
    18 lb ft
    Engine Mount Bolt
    50 N·m
    37 lb ft
    Engine Mount Bracket Bolt
    58 N·m
    43 lb ft
    Engine Mount Heat Shield Nut
    10 N·m
    89 lb in
    Engine Mount Stud
    50 N·m
    37 lb ft
    Engine Mount Through Bolt
    95 N·m
    70 lb ft
    Engine Mount Through Bolt Nut
    10 N·m
    89 lb in
    Engine Oil Filter
    30 N·m
    22 lb ft
    Engine Rear Cover Bolts
    30 N·m
    22 lb ft
    Engine Service Lift Bracket M10 Bolts
    50 N·m
    37 lb ft
    Engine Service Lift Bracket M8 Bolt
    25 N·m
    18 lb ft
    Engine Valley Cover Bolt
    25 N·m
    18 lb ft
    Engine Wire Harness Clip Bolt
    50 N·m
    37 lb ft
    Engine Wire Harness Clip Bolt (at Automatic Transmission)
    2.5 N·m
    22 lb in
    Engine Wire Harness Ground Bolt
    50 N·m
    37 lb ft
    Engine Wire Harness Ground Bolt (at Frame Rail)
    12 N·m
    106 lb in
    Engine Wire Harness Ground Bolt (Left Side of Engine Block)
    30 N·m
    22 lb ft
    Exhaust Manifold Bolts - First Pass
    15 N·m
    11 lb ft
    Exhaust Manifold Bolts - Final Pass
    20 N·m
    15 lb ft
    Exhaust Manifold Heat Shield Bolts
    9 N·m
    80 lb in
    Exhaust Manifold Pipe Nut
    35 N·m
    26 lb ft
    Front Fuel Pipe Heat Shield Nut
    5 N·m
    44 lb in
    Fuel Injection Fuel Rail Bolts
    10 N·m
    89 lb in
    Fuseblock Stud Nut
    14 N·m
    10 lb ft
    Generator Bolt
    50 N·m
    37 lb ft
    Generator Rear Bracket Bolt
    25 N·m
    18 lb ft
    Ground Terminal Bolt
    6 N·m
    53 lb in
    Ignition Coil Bolt
    12 N·m
    106 lb in
    Ignition Coil-to-Bracket Bolts
    12 N·m
    106 lb in
    Ignition Coil Bracket-to-Valve Rocker Arm Cover Studs
    12 N·m
    106 lb in
    Intake Manifold Bolts (First Pass in Sequence)
    5 N·m
    44 lb in
    Intake Manifold Bolts (Final Pass in Sequence)
    10 N·m
    89 lb in
    Intermediate Steering Shaft Bolt
    47 N·m
    35 lb ft
    Knock Sensors
    20 N·m
    15 lb ft
    Negative Battery Cable Lead Bolt
    32 N·m
    24 lb ft
    Oil Filter
    30 N·m
    22 lb ft
    Oil Filter Fitting
    55 N·m
    40 lb ft
    Oil Level Indicator Tube Bolt
    25 N·m
    18 lb ft
    Oil Level Sensor
    13 N·m
    115 lb in
    Oil Pan Baffle Bolts
    12 N·m
    106 lb in
    Oil Pan Bolt (M8)
    25 N·m
    18 lb ft
    Oil Pan Closeout Cover Bolt - Left Side
    12 N·m
    106 lb in
    Oil Pan Closeout Cover Bolt - Right Side
    12 N·m
    106 lb in
    Oil Pan Cover Bolts
    12 N·m
    106 lb in
    Oil Pan Drain Plug
    25 N·m
    18 lb ft
    Oil Pan M8 Bolts - Oil Pan-to-Engine Block and Oil Pan-to-Front Cover
    25 N·m
    18 lb ft
    Oil Pan M6 Bolts - Oil Pan-to-Rear Cover
    12 N·m
    106 lb in
    Oil Pressure Sensor
    20 N·m
    15 lb ft
    Oil Pump-to-Engine Block Bolts
    25 N·m
    18 lb ft
    Oil Pump Cover Bolts
    12 N·m
    106 lb in
    Oil Pump Relief Valve Plug
    12 N·m
    106 lb in
    Oil Pump Screen-to-Oil Pump Bolt
    12 N·m
    106 lb in
    Oil Pump Screen Nut
    25 N·m
    18 lb ft
    Oxygen Sensor
    42 N·m
    31 lb ft
    Positive Battery Cable Fitting
    15 N·m
    11 lb ft
    Positive Crankcase Ventilation (PCV) System Strap Nut - at Right Front Engine Coolant Air Bleed Pipe Stud
    12 N·m
    106 lb in
    Powertrain Control Module (PCM) Connector Bolt
    8 N·m
    71 lb in
    Power Steering Gear Bolt
    85 N·m
    63 lb ft
    Power Steering Pump Bracket Bolt
    50 N·m
    37 lb ft
    Secondary Air Injection (AIR) Pipe Bolt
    20 N·m
    15 lb ft
    Secondary Air Injection (AIR) Switch Valve Bracket Bolt
    20 N·m
    15 lb ft
    Secondary Air Injection (AIR) Switch Valve Bracket Nut
    12 N·m
    106 lb in
    Shock Absorber Bolt
    65 N·m
    48 lb ft
    Spark Plug (All Subsequent Installations)
    15 N·m
    11 lb ft
    Spark Plug (New Cylinder Head)
    20 N·m
    15 lb ft
    Stabilizer Bar Bracket Bolt/Stud
    55 N·m
    41 lb ft
    Throttle Body Bolts
    12 N·m
    106 lb in
    Torque Converter Bolt
    63 N·m
    47 lb ft
    Transmission Bolt (Automatic Transmission)
    95 N·m
    70 lb ft
    Transmission Bolt (Manual Transmission)
    50 N·m
    37 lb ft
    Transmission Cover Bolt
    12 N·m
    106 lb in
    Transmission Fill Tube Bolt
    50 N·m
    37 lb ft
    Transmission Oil Cooler Line Fitting
    27 N·m
    20 lb ft
    Transmission Support Bolt
    57 N·m
    42 lb ft
    Upper Control Arm Nut
    53 N·m
    39 lb ft
    Valve Lifter Guide Bolt
    12 N·m
    106 lb in
    Valve Rocker Arm Bolt
    30 N·m
    22 lb ft
    Valve Rocker Arm Cover Bolt
    12 N·m
    106 lb in
    Water Inlet Housing Bolts
    15 N·m
    11 lb ft
    Water Pump Bolts - First Pass
    15 N·m
    11 lb ft
    Water Pump Bolts - Final Pass
    30 N·m
    22 lb ft
    Water Pump Cover Bolts
    15 N·m
    11 lb ft
    Jul 2009
    Philly
    2000 NBM SS
    Thanks for the quick reply, definitly saving this!
    USA
    Velocity Yellow
    2008 Corvette Z06
    Quote Originally Posted by molecularmann View Post
    No problem!
    2018 Tahoe - Silver - OEM
  1. Lifter guide tray torque spec?
    By MasonWS6 in forum Internal Engine
    Last Post: 03-28-2016, 04:37 AM
  2. Question: torque spec on sway bar end-links
    By 98TransAmWs-6 in forum Suspension and Handling
    Last Post: 04-20-2012, 04:16 AM
  3. 2010 Camaro - Latest Pictures and Spec Sheet
    Last Post: 07-25-2008, 09:37 AM
  4. Need torque spec for brake caliper bracket
    By dwhitez28ss in forum General Help
    Last Post: 06-19-2007, 08:30 PM
  5. HP III/Spec Stage II/Poly Torque Arm Bushing
    By 30birdy in forum Parts For Sale / Trade
    Last Post: 08-17-2006, 08:29 PM
