Results 1 to 13 of 13
Thread: Need your opinions
08-26-2010, 11:34 PM #1Junior Member
- Aug 2010
- Beeville, tx
White- 00' Camaro ss
Need your opinions
Alright well a friend is sellin a maro with a fully rebuilt ls1 motor with 243 heads and cam and all this other stuff. He is sellin it for 4g's only thing is needs to be fixed. Said he got 'Blow-By' driving it he got a quote to fix it and its gonna cost 450, now I was lookin into gettin another maro but should I go for this one or wait for another one to come along.
08-28-2010, 10:03 PM #2
08-29-2010, 04:42 AM #3Junior Member
- Aug 2010
- Beeville, tx
Blow-by occurs when the explosion that occurs in your engine's combustion chamber causes fuel, air and moisture to be forced past the rings into the crankcase. Your engine's rings must maintain an excellent fit in order to contain the pressure.
The causes of blow-by: wear, soot and deposits
As rings and cylinder liners wear away they are less capable of maintaining this seal. Consequently as a car ages the amount of blow-by that occurs can increase.
Soot and deposits left over from incomplete combustion that collect on the rings can also inhibit their seal worsening blow-by.
The effects of blow-by: loss of horsepower and oil contamination and dilution
Blow-by inhibits performance because it results in a loss of compression. When the expanding gases slip past the rings they cannot as effectively push the piston down and make the vehicle go. As a result the car will have less horsepower. This also results in a loss of fuel economy.
When the fuel, air and moisture slip into the crankcase they contaminate and dilute the oil in the crankcase.
Among the many gasses in your compression chamber are unburned fuel, moisture, sulfur dioxide and soot. Once these gasses slip into your crankcase they can dilute into your engine causing great damage.
08-29-2010, 08:57 AM #4
450 sounds way to cheap to fix that problem. also 4 G's is cheap for a late model 4th gen. there has to be something way wrong. I paid 7500 for mine a year ago and it had just a hair over 100,000 miles.
08-29-2010, 09:47 AM #5
08-29-2010, 03:47 PM #6
wow learn something new everday i guess. Thanks Gilly.
08-29-2010, 04:55 PM #7
Wait for another one or be prepared to spend a good deal more than $450
08-31-2010, 02:07 PM #8Junior Member
- Aug 2010
- Beeville, tx
Thanks for the info guys I will just wait for something better to come along
09-01-2010, 04:35 AM #9
09-01-2010, 11:24 AM #10Junior Member
- Sep 2010
- nj
- 1999 saturn
blow by can go both ways. sometimes oil gets into the cylinder past the rings and burns with the air/fuel mixture. usually a slight bluish smoke coming out of the exhaust during high manifold vacuum. for instance after slowing down when you smoke a mustang...(no pun intended). a leak down test is more accurate than a compression test..
09-01-2010, 12:10 PM #11
"blow by" is also a term used when motor oil gets past the seals/bearing in an FI (turbo) vehicle.. Usually on the compressor side.. Just tossing that out there..
Blow by can also happen if the ring gaps were not turned opposite the next ring. Possibility since you said the motor was rebuilt... Can also happen if the engine was not properly broken in as well.. One way of the other you may have to dig into that engine.. I'd walk away unless your heart is set on it.. Just my .o2..
09-01-2010, 11:08 PM #12Junior Member
- Aug 2010
- Beeville, tx
09-01-2010, 11:31 PM #13
Ls1 I need your opinions on these........
By Murder after Midnight in forum Almost Anything GoesReplies: 9Last Post: 11-20-2009, 07:59 PM -
Need your opinions please...
By Lswoo in forum Forced InductionReplies: 8Last Post: 10-28-2009, 07:40 PM -
Opinions
By jetaws6 in forum Firebird / WS6Replies: 8Last Post: 09-20-2009, 04:25 PM -
need some opinions
By a338566 in forum General HelpReplies: 1Last Post: 06-01-2007, 08:06 PM -
next mod opinions???
By clg82 in forum Firebird / WS6Replies: 21Last Post: 04-30-2007, 07:38 AM
