Thread: Opinions
    Member jetaws6's Avatar
    Apr 2009
    Fallston, Maryland
    1998 Trans Am Ws6
    Opinions
    I gotta 98 ws6 m6 and im torn between headers and off road y pipe or 3.73 gears. Which will give me better results at the track right now I just got slp loudmouth 2 and k&n filter and air lid and im hittin 13.4's any thoughts?
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    Quote Originally Posted by jetaws6 View Post
    I would say headers and Y. I have an 02 SS and after headers, Y, lid, and cats removed I DYNO'd 342HP on a Mustang DYNO. From what I understand, our cars typically DYNO 280-290 on a Mustang DYNO. So I picked up close to 50whp and that is going through a 9" which is even less efficient.
    Apr 2009
    Fallston, Maryland
    1998 Trans Am Ws6
    Do you know if pacesetters are flanged or welded on to the y pipe becuase I can get a o/r y for $100 but its flanged.
    okc
    Silver 2002 WS.6
    Red 1989 Formula
    4.10's made a big difference for me, but then my car already had lt's when i got it
    Yeah I agree. I got my 4.11 at the same time as my LTs. I am not sure a 3.73 will be as big of gain as LTs and Y.
    To the OP, is this on the stock 10 bolt? I personally wouldn't put money into it if you plan on ultimately putting down some serious HP numbers.
    Apr 2009
    Fallston, Maryland
    1998 Trans Am Ws6
    I would get a 12 bolt with the gears 10 bolt isnt worth any money
    War Machine BIG GUNS's Avatar
    St. Louis MO.
    00 Trans Am/Auto
    Get the LTs and ORY first. The gears are cheaper and you can get those anytime. Headers and ORY will take a bit more time but, will make a difference in sound and yes. The Magnaflow muffler will bolt up just fine.
    I think they only make a 3" inlet anyways but, can't remember.
    Apr 2009
    Fallston, Maryland
    1998 Trans Am Ws6
    Im not worried about the muffler which is slp btw I was wonderin if the pacesetters lt's are flanged or weld ins becuase the o/r y is flanged
    St. Louis MO.
    00 Trans Am/Auto
    I'm pretty sure that they are flanged. You'd be pretty hard pressed to find weld ins anymore. Most are clamp and forget if you get an ORY to go with it.
    If you use your stock y pipe, I'd discourage that.
    Get the full set up. Most kits will come with the ORY but, if not, find a matching ORY to go with it.
  1. Need your opinions
    By Gillyss in forum Internal Engine
    Last Post: 09-02-2010, 12:31 AM
  2. Ls1 I need your opinions on these........
    Last Post: 11-20-2009, 08:59 PM
  3. Need your opinions please...
    By Lswoo in forum Forced Induction
    Last Post: 10-28-2009, 08:40 PM
  4. need some opinions
    By a338566 in forum General Help
    Last Post: 06-01-2007, 09:06 PM
  5. next mod opinions???
    By clg82 in forum Firebird / WS6
    Last Post: 04-30-2007, 08:38 AM
