Results 1 to 20 of 25
Thread: Easiest way to build an x pipe?
08-26-2010, 06:04 PM #1Senior Member
- Mar 2010
- St Pete, FL
Bat mobile black- 2000 Trans am WS6 M6
Im going to be buying some piping and building an x pipe system with 2 dynomax bullet mufflers. Im going to build it over the axle and all the way to the rear, at first i will not have the mufflers but just straight piping... Does anyone have an experience with building their own x pipes from scratch? And have any tips on this?
08-26-2010, 07:15 PM #2Senior Member
- Oct 2008
- Coral Springs, Fl
Summit has a nice universal one you could make work
08-26-2010, 07:27 PM #3Senior Member
- Mar 2010
- St Pete, FL
thanks i will check it out right now
08-26-2010, 09:33 PM #4
pypes advertises that with a little bit of extra pipe you can make their kit fit too.
08-27-2010, 11:06 AM #5
What exhaust do you have on it now??? I converted my tsp oryp to an x pipe with true duals.
08-28-2010, 08:38 AM #6Senior Member
- Mar 2010
- St Pete, FL
right now i have the pacsetter headers and oryp and i have a hooker cat back... I am thinking of building my own X pipe and rest of the piping and throwing some dynomax bullets in there... How does it differ from your y pipe? I dont want universal kits im doing everything from scratch.
08-30-2010, 07:24 AM #7
I got a sawzall and cut the tsp pipe where the two Go into the collector and put my x pipe there and welded it up them took two 18 in dynomax bullets 4in round and welded them to the x pipe with turndowns right before the axle. I used one rubber mounted hanger between the two bullets and welded it to the mufflers and used the rear seat bracket to hold the bracket to the car on the pass side. the x pipe and bullets are 3in in size. Its a cheap easy way fo having mandrel bent true duals that clear nicely. Mine exhaust is just to the pass side of the driveshaft and torque arm and about 1in from the floor pan. I would send pics but dont have a way to.
08-30-2010, 03:56 PM #8Senior Member
- Mar 2010
- St Pete, FL
damn.. id love to see a pic but i have a mental picture.. Thanks for the input i think i have it down now.
09-02-2010, 08:36 AM #9
Glad to help ya... Now get busy...
09-02-2010, 11:01 AM #10
Custom "X" pipe construction...
If you deside to tackle a custom X-pipe.. Here you go..... Pipe dia. is going to be up to you..
BASIC..
09-02-2010, 11:07 AM #11
09-02-2010, 11:29 AM #12dbl clutch'n like i shld
- Aug 2010
- Oklahoma City, Oklahoma
sebring silver- Y2K SS CAMARO
do the x pipes with true duals really do anything for our cars?
09-02-2010, 01:05 PM #13
09-02-2010, 01:06 PM #14dbl clutch'n like i shld
- Aug 2010
I see cause i already have a ORY and shorty hedders with a dynomax drill core so i didny know if it would be any better than where im at or not
09-02-2010, 05:07 PM #15
09-02-2010, 09:38 PM #16Senior Member
- Mar 2010
- St Pete, FL
thanks smittro for that pic. I have a buddy who builds cars thats going to help me build the system..
09-02-2010, 09:55 PM #17
09-03-2010, 07:33 PM #18
09-07-2010, 11:52 AM #19
09-14-2010, 07:50 PM #20Junior Member
- Mar 2008
- IL
White; Navy Blue Metallic- '01 SS Vert.;'02 RS Coupe
Why not just go with the Bassani system and call it a day?
http://www.bassani.com/part/5798RS5
What was the easiest, and hardest job youve done on your TA?
By Lunatikgixxer in forum Firebird / WS6Replies: 50Last Post: 03-16-2012, 07:58 AM -
Header Modeling Kit Build - Pipe Dream
By Ed Blown Vert in forum General HelpReplies: 0Last Post: 10-21-2011, 09:10 AM -
Easiest way to take out ram air grills?
By patriot1136 in forum Firebird / WS6Replies: 4Last Post: 03-14-2009, 12:15 PM -
easiest fix ever
By egod in forum Firebird / WS6Replies: 9Last Post: 07-21-2008, 08:00 AM -
need help:easiest way to take the oil pan off 99 c5 from my garage with only a jack
By bubbals1 in forum CorvetteReplies: 1Last Post: 10-21-2006, 04:10 PM
