Results 1 to 20 of 51
11-12-2011, 05:16 AM #1
- Mar 2010
- St Pete, FL
Bat mobile black- 2000 Trans am WS6 M6
What was the easiest, and hardest job youve done on your TA?
Lets hear everybodys easiest and hardest job theyve done to their car.
My easiest was probably installing the alternator.
My hardest would probably be the spark plugs and wires. The wires seem to be more of a PITA than the spark plugs themselves.
11-12-2011, 10:30 AM #2
- Jan 2010
- Arlington,Texas
Silver/Black- 00' z28-R.I.P 00' WS6 M6
easiest.....oil changes lol
hardest would be putting in new springs, shocks, lca relo, adj. PHR, and lca relos at the same time. That was one helluva long and painful weekend
11-12-2011, 11:10 AM #3
For me, the hardest job and still is would be changing these damn plugs.
What a sick bastard engineer it was to lay a design out like this for F bodies.
The easiest would probably be swapping out my shifter for a short throw one.
That was a whole 10 minutes.Be who you are and say what you feel 'cause people who mind don't matter, and people who matter don't mind.'
-Nowhereman
11-12-2011, 12:30 PM #4
The easiest job was installing the SLP lid lol, the hardest would probably be the cam swap...but then again its not a TA only a Camaro so who knows how hard that would have been on a TA
11-12-2011, 01:16 PM #5
- May 2010
- Wilkes-Barre, PA
Black/Black- 98 WS6/04 Sierra Dmax
easiest - SLP lid
hardest - rebuilding/building my 4L60e
11-13-2011, 04:53 PM #6
- Jul 2010
- Kearny NJ 07032
sunset orange metallic- 2002 T/A convertible
By far the easiest: Sitting down with the order forms from the dealer to special order my car
By WAAAAAAAAAAAAy far the hardest: Making payments for 5 years.
11-13-2011, 05:48 PM #7
Easiest? Maybe the TB swap for a ported one.
Hardest? Probably a shock swap when I snapped one, the dang mount wouldn't line up and it took forever to compress the springs by hand.
Most nerve racking? The oil pump swap...omg...
11-13-2011, 05:52 PM #8
Easiest - battery swap, oil change, then lid.
After 2X swapping out the axle seal on the 9" became relatively easy - about 20 minutes.
11-13-2011, 06:08 PM #9
Easiest- Just about everything but the headers...
Hardest- Headers... still have nightmares about those...
11-14-2011, 09:46 AM #10
- Jul 2009
- North of the Motorcity
Easiest - Strut tower brace
Hardest(so Far) - wires/plugs
11-14-2011, 09:50 AM #11
- Thornton, CO
Easiest was the headers. Motor was out for that.
Hardest was installing the SPEC 4+. Not so much the install, but the trouble we had. Transmission came down 5-6 times.
11-14-2011, 09:59 AM #12
- Nov 2010
- Upstate Ny
- 99 Formula
i dont look foreward to my alt install , goddamn procharger in the way
11-17-2011, 09:05 AM #13
Easiest - SLP Lid
Hardest so far - swapping the springs on the front shocks. Damn bolt rusted & seized. Had to use a hammer and chisel to cut off. Every blow of the hammer was absorbed by the shock. Took 45 mins for one damn shock.
11-17-2011, 10:00 AM #14
Ok everyone, now that you've scared me to even look at the plugs, does anyone have a good tip for removing the right rear plug ? Last weekend I was fooling around under the hood and thought maybe I should change the wires & plugs. Maybe not ?????
I've replaced the suspension underneath by myself on my back but this sounds like a real challenge.
11-17-2011, 10:12 AM #15
- May 2010
- Wilkes-Barre, PA
Take the coil packs off and the air tube off the manifold. Then you can get at it but its still a pain.
11-17-2011, 10:46 AM #16
11-17-2011, 10:59 AM #17
Easiest - air lid
Hardest by far was installing poly motor mounts
11-17-2011, 01:08 PM #18
- Oct 2011
- CT
Black- 1993 Trans Am
do it cold, place the spark plug socket on then the ratchet then switch from top and bottom as your arm starts to burn from being jammed
11-17-2011, 03:34 PM #19
11-20-2011, 02:33 PM #20
easiest job for my TA i guess would be lid or short stick swap
hardest job.. FLYCUTTING!!! by far a huge pain in the @$$pulled the motor for that and swapped in some poly mounts while at it.
Most Twisted movie youve ever seen
By ice97ta in forum Almost Anything GoesReplies: 70Last Post: 06-03-2009, 05:19 PM -
Hydroxycut gives you the look youve been dying for
By Zapper2003 in forum Almost Anything GoesReplies: 41Last Post: 05-04-2009, 02:24 PM -
DETROIT VOTED worst/ hardest city in country..
By greatwhiteZ28 in forum Almost Anything GoesReplies: 15Last Post: 11-26-2007, 02:35 PM -
Hardest riders in Harlem!
By ss~zoso~ss in forum Multimedia SectionReplies: 13Last Post: 01-22-2007, 11:31 AM -
college-hardest major
By number77 in forum Almost Anything GoesReplies: 25Last Post: 03-28-2006, 01:03 PM
