    Member qwik219d9's Avatar
    Sep 2008
    Atlanta, GA,Ft.Walton Bch,FL
    Blog Entries
    1
    99 ws6
    connecting 4th guage where to get +12V
    I'm wanting to connect a 3rd guage I allready have 2 guages and a radar detector connected to the inside AUX. inside side fuse box so it's maxed out with the 15amps.
    I'm thinking maybe connect my wide band to the lower cig. lighter/ +12V since it's a swicthed +12V power supply.
    I was thinking of using the air pump circuit sense I have removed the AP.
    any better suggestions.
    Thanks
    Member Head Hunter's Avatar
    Jul 2010
    Fisco, TX
    1999 Trans Am WS6
    Wish I could help but haven't a clue.
    I pulled power for my cutout from the front underhood electrical box. Like you, I had maxed out my only open power source in the dash panel. I believe in the underhood box it was an open circuit for something that our cars are not equipped with, however, the secondary air fuse may work as well.
    Jul 2009
    North of the Motorcity
    Custom Swirly Black
    2001 WS6 M6
    3 guages and a radar maxed out a 15amp? I doubt it. My fogs on my jeep are 100W a peice and they're on a 10amp fuse.
    You should be alright with using the same circuit, if not, put a 20amp in.
    sounds like you have quite a bit of stuff going on there. You can definitely pull the 12v from the cig lighter or use the a.i.r. pump circuit. I would probably try to keep from running everything to the ragged edge and run a single line with a junction block and fuse everything individually.
    Veteran Hi-Po's Avatar
    Florida
    1999 TA WS.6
    I did like 0rion stated awhile ago and it worked nicely. Ran a dedicated power wire to a added fuse block, and everything received its own fuse. Also, everything was on a relay as well. There's a write up with pictures laying around here somewhere.
    I ran a heavier gauge wire out of my dash panel and then split it to feed everything. Unless you add a separate junction block, like Hi-Po and 0rion, things get a bit messy with everything being tied in. Not a bad idea to bring in another feed imo.
    Florida
    1999 TA WS.6
    http://www.ls1.com/forums/showthread.php?t=121134
    There you go. Gosh that thread is messy!!! I did have a diagram drew out for someone else once upon a time also. It described which wire was going where and why. This may not be the route your looking to take, but its an option. Good luck
    Messy? Like this?
    Florida
    1999 TA WS.6
    Messy? Like this?
    I seriously had to do a double take and make sure that wasn't one of my pictures!
    LOL -- It did look a lot better once everything was tied together.
    Sep 2008
    Blog Entries
    1
    99 ws6
    wiring options
    Quote Originally Posted by KMdef9 View Post
    I have a 5 amp fuse on each of the 3 allready coonnected read here the total currnet draw on this AUX should not exceed 15 amps.
    yes I'm thinking 15amp on the AUX circuit is enought.
    I would really like to have an auxliary fuse box & have an individaul circuirt for each guage.
    I plan an electric cutout next spring so a block would be very nice to keep the wiring neat organized and labled.
    however I would prefer to have this fuse box under the dash.
    ?would I have to run a like #8AWG or bigger +12V power wire from the engine bay fuse boxs (connect to the post under the red cover inbetween the 2 fuse box's) to feed this auxcilary box?
    ? A relay and a auxcilary block can it be wired diretly to the battery since the relay has a swicthed +12V to turn this block on? if yes this would be much easier.
    yes I read this stickie very good writeup.
    you did that for me a while back thanks again for explaining I would really like the extra fuse box under the dash you're thoughts on wiring under the dash. mainly on the +12V feed line.
    I've have this guage for a while and have taken my time installing it.
    I have the guage mounted, grounded & recently had the O2 bung welded into the driver side Y, so now I'm anxious to finally connect this wide band to check out my tune.I would prefer not to use the lower cig. lighter circuit even if tempary but probably will untill I figure the best way to wire up a extra fuse block.
    Thanks Guy's for helpfull advice
    here's what I have done so far.
    image of the O2 bung I choose this spot because it's close to the LT collector, access hole and on driver side away from the #7 lean
    cylinder.(from what I've read the driver side gives more accurate readings
    feel free to advice or constructively critazie
    Oh and thanks PAJeff02 & bigrondownhiller for you're good advice
    I'll most likely end up w/ something like this even though it's pricy.
    http://www.jegs.com/i/Painless-Perfo...50#moreDetails
    or this. I like this one better from HIPO 6 connects would be enought for furture growth like DC/AC power inverter & radar descambler I plan.
    http://www.electricalconnection.com/...on/pp-univ.JPG
  1. Does anyone know how to fracture a connecting rod?
    By SMWS6TA in forum General Help
    Last Post: 07-26-2012, 06:34 PM
  2. Connecting rods?
    By 1999sscamaro in forum Internal Engine
    Last Post: 09-11-2010, 07:18 AM
  3. connecting rod
    By 99Firehawk#58 in forum Internal Engine
    Last Post: 07-03-2007, 04:14 PM
  4. Triple guage pillar and cobalt guage for sale
    By mikewood21 in forum Parts For Sale / Trade
    Last Post: 06-20-2006, 03:47 PM
  5. connecting Autometer D-PIC
    By swisschevy in forum General Help
    Last Post: 08-08-2005, 11:10 AM
