Results 1 to 2 of 2
Thread: connecting Autometer D-PIC
08-08-2005, 11:05 AM #1swisschevyGuest
I've recently purchased a Autometer D-PiIC and installed it in the in the lower middle of the instrument panel, left of the cigarette lighter. Now it needs connection to a power source that works via the ignition switch, the dash lightning and a goog engine ground. Where is the best place and the easiest place to connect it? I don't want to disassemble 50% of the dashboard if possible. Any suggestions? Please let me also know the colors of the cables onwhich the D-PIC has to be connected.
Thanks for every answer.
Swisschevy
08-08-2005, 11:10 AM #2Grand Imperial Wizard
- Retired Outlaw Sum Bitch
RAP (retained accessory power) lead such as the
switched lead of the radio...lemme see if I recall ( I'm an old man
)...2000 Camaro correct.....I beleive in the fuse panel it calls out RADIO.....the RAP lead is right there.....I want to say it is a pink wire....you should be able to find the RAP 12V Switched lead in the fuse panel..look for radio...test it with a simple volt meter to insure you have switched power.....
OE Connecting Rods
By NoQuarter in forum Internal EngineReplies: 1Last Post: 05-27-2014, 05:04 AM -
Does anyone know how to fracture a connecting rod?
By SMWS6TA in forum General HelpReplies: 8Last Post: 07-26-2012, 06:34 PM -
Connecting rods?
By 1999sscamaro in forum Internal EngineReplies: 4Last Post: 09-11-2010, 07:18 AM -
connecting 4 guage where to get +12V
By qwik219d9 in forum General HelpReplies: 11Last Post: 08-13-2010, 04:02 AM -
connecting rod
By 99Firehawk#58 in forum Internal EngineReplies: 2Last Post: 07-03-2007, 04:14 PM
