Thread: T56 conversion
08-08-2010, 04:47 PM #1Junior Member
- May 2010
- Savannah, TN
Navy Blue Metallic- 1998 Trans Am
T56 conversion
Ok guys. Ive started my t56 conversion in my 98 trans am. I have a t56 out of an 06 GTO. I know I need a gto starter and a different shifter cup to make it work with the fbody. I have questions about the clutch, flywheel, pressure plate and all those goodies. Do i need to purchase a clutch kit for a trans am or a gto? or does it matter? Also My transmission didnt come with the reverse lockout solenoid or the reverse light sensor. Not just the connectors but the actual thing that goes into the transmission. Where can i find these? Also can anyone help make the wiring easier? break it down for me?
Any and all help is greatly appreciated!
08-08-2010, 04:51 PM #211 years of bangin gears
- Jan 2009
- North Jersey
I don't think there are any differences between clutches for the GTO and T/A. If you are going from A4 to M6, then you will need the wiring harnesses from an M6 T/A as I think the GTO and T/A both use a Tremec. Others will assist.
08-08-2010, 05:21 PM #3Junior Member
- May 2010
- Savannah, TN
Also, i need to replace the input shaft. Since the tranny is out of an 06 GTO, do i need a GTO input shaft or can i use a trans am input shaft?
08-08-2010, 05:28 PM #411 years of bangin gears
- Jan 2009
- North Jersey
I don't know if you can swap the input shafts from the GTO and T/A.
08-08-2010, 05:34 PM #5Junior Member
- May 2010
- Savannah, TN
So i should put a GTO input shaft in and get a trans am clutch kit to work with my T/A engine?
08-08-2010, 05:36 PM #611 years of bangin gears
- Jan 2009
- North Jersey
Check our sponsors to do some cross referencing for the T/A clutch and GTO clutch to see if they both use the same part number. Can't hurt.
08-08-2010, 05:45 PM #7Junior Member
- May 2010
- Savannah, TN
08-09-2010, 06:56 PM #8
IN lbs to FT lBS Conversion
By SMWS6TA in forum General HelpReplies: 4Last Post: 09-24-2010, 02:28 PM -
Ram Air conversion?
By UKXK189 in forum Firebird / WS6Replies: 13Last Post: 06-28-2007, 09:40 AM -
Ls1 vs Lt4 conversion
By bandit-00 in forum Firebird / WS6Replies: 14Last Post: 10-24-2006, 07:26 PM -
FS: T56 conversion for LS1
By 1badchicken in forum Parts For Sale / TradeReplies: 1Last Post: 10-24-2006, 01:30 PM -
Conversion to Ram Air
By 2001bird in forum External EngineReplies: 0Last Post: 10-19-2006, 08:58 PM
