    Apr 2010
    Illinois
    arctic white
    98 Camaro SS
    new a/c compressor doesn't work
    I'll start by saying I bought my 98 ss about 5 months ago and the a/c compressor was locked up and the belt gone(of course). I just got around to installing a reman unit along with a reciever dryer. I flushed the whole system one pice at a time, reassembled everything then drew a vaccum on the system for about 20min. I understand I may need to jumper accross the pressure switch to make the compressor run until The system gets some freon in it, but that won't even make the compressor run. I checked voltage at the compressor pigtail and have none so I don't think its a bad compressor. any insight from someone smarter than me would be greatly appreciated!
    Single Malt rbob93's Avatar
    Ft. Lauderdale, FL
    Sebring Silver
    2000 CamaroSS
    Did you replace the orifice tube? Could be clogged with crap from the dead compressor.
    As soon as you put some refrigerant in the system the compressor should begin pumping.....no need to jump it.
    Apr 2010
    Illinois
    arctic white
    98 Camaro SS
    yes I replaced the orifice tube also, I put almost 1 full can of 134 in but I still dont seem to be getting 12 volts to the compressor. I'm hoping ther is a fuse hiding somewhere, but I think I've checked them all.
    Pittsburgh
    2008 Hummer H3
    Quote Originally Posted by arcticss98 View Post
    Not sure what the LS1 requires but it may need more than just one can of r134a when refilling from empty.. Don't forget to wear eye protection messing with refrigerant.
    Apr 2010
    Illinois
    arctic white
    98 Camaro SS
    I figured it out! I replaced the refrigerant pressure sensor located near the orifice tube on the high side line and, watta ya know, it works. ICE COLD AIR! I don't know if one had anything to do with the other, but it works now.
  1. Help: installed new MB & processor now OS doesn't work.
    By SMWS6TA in forum Computers / Gaming
    Last Post: 04-15-2013, 10:23 AM
  2. Doesn't anyone work around here?
    By rapter34 in forum Almost Anything Goes
    Last Post: 05-28-2008, 03:32 PM
  3. won't come out of 1st, speedo doesn't work.
    By RyansREDcamaroSS in forum Automatic Transmission
    Last Post: 02-18-2006, 08:33 AM
  4. Activation doesn't work
    By PAGregSS in forum Request and Feedback
    Last Post: 11-04-2005, 10:53 AM
  5. SideMarker doesn't work correct..
    By Ruhrpott in forum General Help
    Last Post: 10-19-2005, 05:13 PM
