Results 1 to 3 of 3
Thread: Power Steering Cooler?
07-28-2010, 03:41 PM #1
I decided to go out and do some routine maintenance and check fluid levels in the TA. Power steering fluid looked like a vanilla milkshake. Next, the radiator. No orange fluid. Chocolate instead. I proceeded to stick my finger in it and its gooey. Think I may have blown the power steering cooler. After cam install 7 weeks ago, I put new fluid in the radiator. The fluid I drained wasn't bad, so it has just happened in the last couple weeks. It hasn't ran hot on me and drives fine, but it can't be good. Am I on point with my diagnosis? Will the power steering fluid in coolant system mess my heads up?
Also, how can I verify that my cooler did take a shit on me?Last edited by Speed_kills_WS6; 07-28-2010 at 03:46 PM.
07-28-2010, 04:39 PM #2
You already verified it, by the mixing of fluids, did you check your engine oil? Your going to have to replace it and flush the system a few times to remove all the grime and build-up.
07-28-2010, 06:31 PM #3
I started the car with radiator cap off. Pure dex-cool flowing from the throttle body back into the radiator. I'm going to replace the power steering cooler & flush the system a couple times. All the oil must be sitting on top, so maybe it'll go easy. I'll check the oil tomorrow to make sure I don't have major trouble.
Do you run a Power Steering cooler?
By b.lee in forum External EngineReplies: 16Last Post: 12-07-2020, 02:55 PM -
By DUBB in forum External EngineReplies: 8Last Post: 08-22-2010, 11:38 AM -
Looking for Power Steering Oil Cooler
By NOS99HAWK in forum Parts Wanted / TradeReplies: 4Last Post: 07-02-2009, 04:18 AM -
By knoll5150 in forum General HelpReplies: 2Last Post: 12-03-2007, 08:42 AM -
By Blackout01 in forum General HelpReplies: 2Last Post: 08-03-2007, 09:54 AM
