Results 1 to 14 of 14
07-27-2010, 11:51 PM #1
- Aug 2009
- Clovis, California
Sunset Orange- 2002 WS6 Trans Am
These keep poping up while driving
While i am driving these lights come "Service Vehicle, ABS Inoperable, Brake, TCS Off" this randomly happens while i am driving and idk if i can get the Service vehicle code read, and idk what is wrong or wat i need to do I r very very scured =X can someone help me plz. I assume it is something to deal in the Rear differential area but idk cuz i just know those three things all deal back there. Is it borked? I can still brake and use it, but i am afraid cuz i freaked out when i saw SES light n went and got new O2 sensors just so i wouldnt have to worry about it coming on
07-28-2010, 12:22 AM #2
Have those pop up periodically when I get done with a pass at the track and I am particularly hard on the brakes. Subscribed
07-28-2010, 12:42 AM #3
- Aug 2009
=x it is just my daily driver, n it comes on at random moments, no hard braking or launching, just driving around, there is new pads and rotors, n it has me very scurred. like it sometimes does it when i just start the car, the scariest time was when i was goin into a hairpin turn, n it was the first time the car did that there was no hard braking, but seeing TCS off right on those turns when u need it most is kind of scary especially when there is a deep ditch full of water taunting you ;.;
07-28-2010, 06:08 PM #4
- Apr 2008
- Madison, WI
You need to have your ABS codes scanned. You most likely have a wheel speed sensor that is going bad.
07-28-2010, 09:03 PM #5
- Aug 2009
Well it stopped doing that today =X or atleast it didnt do it once today, but i did do something different, cuz i hadz a bad day n new tires r coming in soon~
07-28-2010, 09:04 PM #6
- Aug 2009
And how do u change one of dem? tire speed checkin thingmajjigers
07-28-2010, 10:18 PM #7
- Feb 2010
- north bay california
Black- 00 camaro ss M6 #6695
Mine had the same problem
I replaced the speed sensor
And the light still there
I was pissed00 ss blk m6 " STOCK" strano springs, slp bilstein shocks, adj LCA, adj panhard bar, relocation brackets, 2 point SFCs welded,OEM zo6 rims black, magnaflow exhaust, CME exhaust,E/cutout, slp grille, custom front plate mount, HIDs, whistler mod, side moldings delete, slp air lid, ported and polished TB, strut tower brace, 3.73s gears, and some other parts to list!
02 tahoe Z71 blacked out
98 z28 red m6 sold
07 zx6r ninja flat/black sold
08 zx6r ninja sold
07-29-2010, 07:29 AM #8
- Jun 2008
- Annapolis, MD
BLK/BLK w/CGM Stripes- 2010 Camaro 2SS/M6
does everything else work when that happens?
Check your ABS block connector just to make sure it isn't burned up. I fixed a car that had that kinda issues and the ABS block connector had a short in it and burned the internals and shorted out a bunch of stuff. In that case, even the gas gauge and tach stopped working. Replaced the connector and the electronic portion of the ABS block and it fixed it all.
07-29-2010, 05:14 PM #9
- Apr 2008
- Madison, WI
Depends on which one is bad. Have you had the codes scanned yet? The front 2 sensors require you to replace the whole wheel bearing and hub assembly. The rears are just an easy sensor to unbolt from the rear axle.
Yeah but you had 2 codes and 2 problems. Hehehe...you didn't believe me did you? I told you you had 2 problems.
07-29-2010, 05:22 PM #10
- Feb 2010
Yeah I remember that lol
1 problem was the speed sensor
And the other one was the abs unit I think
But the guy said it was only the speed sensor
07-29-2010, 05:48 PM #11
lol it's funny but i had those light then i changed my pulleys and than again when i had alternator problems cuz it was giving a high charge
08-10-2010, 08:19 AM #12
- Aug 2010
- Richmond VA
Dark Blue metalic- 2001 TransAm WS6
Error codes on dash popping up
I have a 2001 WS6 that displays ABS INOP, TCS Off, Brake, and Security intermittently. Is this the same problem? Any suggestions?
08-10-2010, 01:14 PM #13
- Apr 2008
- Madison, WI
ABS INOP, TCS Off, and Brake lights are related. You need to have the ABS computer scanned for codes.
08-10-2010, 06:43 PM #14
- Aug 2010
- Richmond VA
Will do. Thank you
poping noise
By ls1speedster in forum Firebird / WS6Replies: 2Last Post: 12-12-2007, 03:31 PM -
Reverse gear poping out.
By SPDemon81 in forum Manual TransmissionReplies: 8Last Post: 06-18-2007, 06:22 AM -
poping sound
By *JC* in forum Suspension and HandlingReplies: 3Last Post: 04-10-2007, 02:04 PM -
poping in to say hello
By zbaron in forum Firebird / WS6Replies: 8Last Post: 10-30-2006, 02:34 PM -
My air lid clips keep poping off
By 1959ls1 in forum External EngineReplies: 10Last Post: 07-09-2006, 08:36 PM
