Thread: Reverse gear poping out.
05-29-2007, 08:57 PM #1Junior Member
- Aug 2006
- S.F.
Black- 99 Camaro Z28
When I put the gear in reverse, then while trying to reverse the gears pops out? What is wrong?
05-30-2007, 08:18 AM #2Junior Member
- Sep 2005
- Michigan
Onyx Black- 2000 Berger SS #21
Mine did the same thing. Turns out the shift pads were toast. I missed 5th once and overpowered the reverse lockout and tried to push it into reverse at about 50mph. Probably melted the plastic stock reverse fork shift pads when I did this as they were pretty much gone. stock replacement pads are $1.17 each, bronze ones from T56 Rebuilds are $30.00 a pair. 2 required. I noticed the synchro was worn becasue of this as well so I flipped it over (disassembled the center portion and assembled with the unused engagement teeth from the other side of the synchro so they would engage the gear instead of the worn side.) The reverse gear itself looked OK. I have not put the tranny back in yet but the fix was relatively simple if you have the right tools. It may be me a few weeks before I get it back in to test it, but it looks like it goes into gear a lot better with shift pads.
05-30-2007, 05:51 PM #3Junior Member
- Aug 2006
- S.F.
Coo, right on for the info let me know how that goes you put it back on...Now that u mention it..I also miss 5th gear a couple of times it wasnt pretty.
06-03-2007, 06:10 PM #4
06-04-2007, 03:14 AM #5
Yeah $600 is steep when you can throw another $200 and have it upgraded to handle 600+ TQ. Then you don't have to worry about it again...
06-04-2007, 03:50 PM #6Junior Member
- Sep 2005
- Michigan
06-05-2007, 05:45 PM #7Junior Member
- Sep 2006
- Navarre, Oh.
Red- 1999 Trans Am
If your tranny mount is broke it will do the same thing. A much easier fix so I'd see if thats it first. IMO
06-05-2007, 05:46 PM #8Junior Member
- Sep 2006
- Navarre, Oh.
Red- 1999 Trans Am
^ Didnt make sense to me at first (why a mount on the outside would pop the shifter out of reverse) but when AMCO explained it to me, it made sense. When its broke not only does the tranny sit a little lower it also twists with the motor.
06-18-2007, 06:22 AM #9Junior Member
- Sep 2005
- Michigan
T56 Reverse gear/syncro replacement question
By Bigdaddytiberius in forum Manual TransmissionReplies: 0Last Post: 03-20-2012, 02:26 PM -
Having an issue with Reverse gear (6sp)
By nasmith7 in forum Manual TransmissionReplies: 2Last Post: 03-15-2010, 12:02 AM -
Reverse Gear Problem
By D_OPP_99LS1 in forum DrivetrainReplies: 4Last Post: 05-05-2008, 10:13 AM -
Reverse Gear
By Blackout01 in forum Manual TransmissionReplies: 3Last Post: 08-26-2007, 04:17 PM -
I can't get into reverse gear!
By romulo13 in forum General HelpReplies: 3Last Post: 09-05-2006, 12:48 PM
