    maryland
    blue
    2000 trans am
    replacing rear bearings bolt in differential stuck
    Im replacing the rear wheel bearings in my 2000 trans am. Never done this before ive got the brakes rotors off n the cover to the differential popped of now im at the point where im suppose to remove a bolt that holds in what i believe to be called a cross shaft. im using a 8mm open ended to try to turn this bolt but its starting to stip. its to narrow to get a socket wrench in there n im wondering if its safe to spray bolt breaker in there or what the hell to do to loosen this bolt cuz i know it and the cross shaft have to come out so i can remove the axle shaft to replace the old bearings and seals.
    Member importhater81's Avatar
    Oct 2009
    chicagoland,Il
    02 ss camaro
    There is locktight applied to that bolt from the factory. Don't use a 12 pt wrench.. especially the open end,it will round the head of the bolt. I use a shallow 1/4" drive 6 pt 5/16 socket as it is slightly smaller that an 8mm.
    It is alright to use penetrating oil on the bolt.
    You can even use a torch just don't go crazy with it and melt anything.
    maryland
    blue
    2000 trans am
    i failed
    Tried penetrating oil n a 1/4 drive n broke a brand new craftsman socket wrench lol
    Oct 2009
    chicagoland,Il
    02 ss camaro
    Quote Originally Posted by malossavich View Post
    Get another socket wrench. Heat the carrier around the bolt with a torch, bolt should come out with ease.
    Bragg NC
    Met. Sunset Orange
    01 SS
    Yepp, a little heat should do the trick...
    J
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    When in doubt...get the torch.
  1. Wanted: 12 bolt rear drop in differential for 1997 Trans Am
    By 1997transam in forum Parts Wanted / Trade
    Last Post: 11-24-2013, 08:37 PM
  2. Question: replacing rod and main bearings...do's and dont's?
    By jiveass in forum Internal Engine
    Last Post: 11-14-2011, 08:42 AM
  3. used stock differential working 12 bolt or 9"
    By 402 Guru in forum Parts Wanted / Trade
    Last Post: 11-18-2009, 08:14 PM
  4. Replacing endlinks, bolts stuck
    By thephalanx in forum Suspension and Handling
    Last Post: 06-24-2009, 03:39 AM
  5. For Sale: Rear axle bearings for a GM 10 bolt
    By Y2KPewterSS in forum Parts For Sale / Trade
    Last Post: 04-30-2009, 05:52 PM
