Results 1 to 10 of 10
    Sep 2009
    Livermore, Ca
    Blue
    2004 GTO
    Anti Theft Problem?
    So today my car decided not to start. Well, it would start but instantly stall. After some troubleshooting I figured out what is going on but I don't know how to fix it or why it is happening. Basically once I turn the car off (for any amount of time) it won't start unless I use the key to lock the doors then unlock them, then it turns over just fine and stays running. I think for some reason the car believes it is being stolen and it is the anti theft system not allowing the car to stay running. Am I close to being right on this or not?
    Member derbs's Avatar
    Jun 2006
    iowa
    IBM
    04 GTO
    Is it throwing any codes? I maybe wrong but if it was the Antitheft it would light up the check light???
    Sep 2009
    Livermore, Ca
    Blue
    2004 GTO
    Nope not a single code. When it does not start the light that shows the car with the padlock by it continues to flash the whole time.
    Jun 2006
    iowa
    IBM
    04 GTO
    Do you have a spare key? Try starting it up with the spare your fob may be f'ed up.
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    Wouldn't trigger a CEL. Car would just shut down. Sometimes the alarm will sound and once you start it, a msg will appear reading "VEHICLE STARTED WITH KEY". Sounds like your fob is on its way out.
    Sep 2009
    Livermore, Ca
    Blue
    2004 GTO
    Quote Originally Posted by derbs View Post
    I am using the spare key the old one went a while back. I was thinking that it might be the fob but the key does start the car I just have to lock it then unlock it. If it was the fob wouldnt it not start it at all or intermittently without having to do the lock/unlock step?
    Sep 2009
    Livermore, Ca
    Blue
    2004 GTO
    Forgive my ignorance but what is a CEL? My alarm never sounds during this process.
    CEL= Check Engine Light
    My brother has had this exact issue with his 06. Not sure if he's ever gotten it fixed or not but I'll ask him when I see him. If I recall he even got a new key/fob from the dealer and it still done it. I'll have to ask him though. I'll update the thread in the next few days as I usually talk to him every 2-3 days.
    North Jersey
    2004 GTO M6
    That sounds like a BCM issue right there Orion.
    King of Lurkers ne0fiend's Avatar
    Clearwater, Florida, United St
    04M6 GTO
    Cool
    Quote Originally Posted by Whatarush View Post
    The key and the FOB are different all-together. The FOB is an electrical part, used as a communication medium between the end user, and the vehicle. The actual key (the metal piece) is just a mechanical middle-ware used to turn the tumblers. My point is, the FOB could be toast and the key would still unlock/lock the vehicle with no problem and vise versa.
    Orion mentioned his brother's Goat had a problem like this and may still be having it, despite the FOB replacement; that makes me lean ever further toward BCM/PCM problems.
    I'm going to agree here -
    I reccomend power-cycling the PCM first;
    Unhook the battery,unbutton your coolant box and set it aside, slide the heat shield up and out, pop the plastic housing off (snaps), remove the lid then take out the 8mm or so bolts holding the connector blocks on. Let the unit sit for 60-90 seconds then button it back up.
    That would reset any short term bugs.
    Thanks.
  1. Random no-crank. Anti-theft?
    By turbojimmy in forum General Help
    Last Post: 04-04-2010, 07:04 AM
  2. Radio Anti theft
    By 99WS6POWER in forum Stereo and Electronics
    Last Post: 06-29-2009, 12:31 PM
  3. Best Alarm/Anti Theft Idea??
    By CamaroFan71 in forum Stereo and Electronics
    Last Post: 10-31-2008, 07:44 PM
  4. 01 SS anti theft
    By Texasbadger in forum Camaro / SS
    Last Post: 06-15-2008, 05:16 PM
  5. anti theft help!!!
    By blackbirdbrain89 in forum General Help
    Last Post: 04-23-2008, 03:21 PM
