Results 1 to 10 of 10
Thread: Random no-crank. Anti-theft?
04-03-2010, 03:08 AM #1
Ok, this has been driving me nuts since I bought the car a year ago. Sometimes, completely at random, the car won't crank. The battery is fine. It's definitely an anti-theft or clutch interlock thing. I can't duplicate the behavior, and I don't know what fixes it. Sometimes I mess around with the shifter, other times I hit "unlock" on the fob several times, other times I lock and unlock the doors. Sometimes all these gyrations work, other times I have to let it roll and dump the clutch to get it running. Weird thing is that it will do it whether I've locked the car or not (I assume hitting LOCK on the keyfob engages the antitheft).
I thought maybe it was the pellet in the key, so I got my spare out. Same deal.
Ideas?
04-03-2010, 07:13 AM #2Junior Member
- Jul 2007
- Maryland
next time it it happens see if the security light is lit, if so it's the key or lock cylinder. If the light is not lit check the conections at the starter, I've had a bad conection the did the same thing.
04-03-2010, 10:22 AM #3Senior Member
- Apr 2008
- Madison, WI
you could try doing the security system bypass and see if that helps
VATS bypass
04-03-2010, 11:02 AM #42002 Arctic White T/A
- Sep 2009
- Houston , Texas
Metallic Pewter- 2002 SLP Firehawk
i did the bypass and still no crank no nothing, just a light click
04-03-2010, 03:21 PM #5
04-03-2010, 04:40 PM #6
I don't think the security light is lit, but I'll look for it next time.
There's not hint of a click or anything. Definitely being electronically locked out somehow. I don't think it's a bad connection.
Jim
04-03-2010, 07:15 PM #7Senior Member
- Jan 2010
- texas
silver- 2000 formula
sounds like the VATS bypass..............did not bypass
04-04-2010, 06:47 AM #8
mine does the same thing but my guages actually max out then go back normal
04-04-2010, 06:56 AM #9
04-04-2010, 07:04 AM #10Senior Member
- Apr 2008
- Madison, WI
measure across both sides of the pellet
Help: Anti Theft Problem?
By Whatarush in forum GTOReplies: 9Last Post: 07-19-2010, 03:26 AM -
Radio Anti theft
By 99WS6POWER in forum Stereo and ElectronicsReplies: 2Last Post: 06-29-2009, 12:31 PM -
Best Alarm/Anti Theft Idea??
By CamaroFan71 in forum Stereo and ElectronicsReplies: 17Last Post: 10-31-2008, 07:44 PM -
01 SS anti theft
By Texasbadger in forum Camaro / SSReplies: 24Last Post: 06-15-2008, 05:16 PM -
anti theft help!!!
By blackbirdbrain89 in forum General HelpReplies: 2Last Post: 04-23-2008, 03:21 PM
