Thread: axle oil leak
    Junior Member silver35thss's Avatar
    auburn, al
    2002 ss camaro
    axle oil leak
    got up after going to the dyno to see some oil on the ground beside my drivers side rear tire. thought it might be a brake line,, it wasnt, so i figured it was the oil seal on that axle. got in there to see everything was coated nicely with rear end gear oil. ( calipers, pads, rotors, inside of the rim, the tire, and the drip was coming from the backside where the emergency brake connected in. I got a new seal from the gm dealer and put it in , took about5 hours and got it all back together just to get up this morning and see some more leaking on the ground, now its not near the leak it was at first but it is still coming out somewhere. has anyone else had a problem with these seals, or could the leak be coming from somewhere else? need some help on this one?
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    Could be coming from somewhere else, or you might have installed the seal improperly. You might have to spray that area with brakekleen and compressed air to see where exactly the leak is coming from, whether it be the same area you replaced the seal, or maybe a cracked axle tube.
    North Jersey
    2004 GTO M6
    Oh...check the shock as well. You might have a blown shock and it's leaking.
    Any chance you missed some of the fluid when you cleaned everything up and that is what you are now seeing? It was probably slung all over the place by the rotating wheel.
    auburn, al
    2002 ss camaro
    yah, it was,, i mean it was everywhere, but you know i cleaned it all up really good, or so i think.. ill def. check it again b4 i start tearing it all apart again.
    North Jersey
    2004 GTO M6
    Make sure to check your rear shocks as well. I posted that before, but shocks can leave puddles when blown.
    auburn, al
    2002 ss camaro
    going to check that when i get home. trust me.. i hope it is that,,, excuse to do some suspension upgrades then!
  1. Axle Leak?
    By 35th-ANV-SS in forum Drivetrain
    Last Post: 03-12-2011, 11:01 PM
  2. SLP axle back VS Borla axle back
    By DVrec21 in forum External Engine
    Last Post: 01-05-2011, 03:45 AM
  3. Help: Moser rear axle leak
    By CAMSS2002 in forum Drivetrain
    Last Post: 05-21-2009, 08:32 PM
  4. axle seal leak
    By issues in forum Corvette
    Last Post: 08-09-2007, 03:37 AM
  5. ttop leak, hatch leak, and window motor problems
    By ATCharming in forum General Help
    Last Post: 07-23-2007, 02:30 AM
