Results 1 to 20 of 27
Thread: O2 sensors keep going out
06-27-2010, 07:33 AM #1
- Mar 2010
- melbourne florida
navy blue metallic- 2002 camaro ss
I keep having a problem with my two front (upstream) O2 sensors going out. I have a cat delete and when I had the car tuned I had the rear O2's deleted. Twice now I replaced my front O2 sensors and at 70.00 a pop I'm getting pissed. Could the tune be the problem? When I replace the sensors my ses light goes out and after a few days it's back on again. The car runs rich and the fuel mileage goes out the window, I also notice a decrease in performance. The car doesn't run rough but the code reads upstream O2 sensor bank 1 bad/rich. I still have the stock manifolds on the car as well. Any help is greatly appreciated.
2002 Camaro SS/M6. Volant CAI, 80mm TB w/spacer, cat delete w/ ory, borla XR-1 w/ cme, custom tune, 3.73's, 8,000k HID headlights and foglights, 19" staggered ruff 278 wheels.
06-27-2010, 07:34 AM #2
What brand sensors and are you utilizing an extension harness?
06-27-2010, 07:38 AM #3
06-27-2010, 07:40 AM #4
Most members have had great luck with the Bosch 13111's in their LT's -- I run the same setup. Any chance you have a wiring issue? Are codes being thrown for both banks? Can you read your air/fuel ratio or fuel trims?
06-27-2010, 07:49 AM #5
- Mar 2010
- melbourne florida
Actually yes, codes are being thrown for both banks and saying running rich. Thats why I just replace both O2's. I also think I have a small vaccum leak as I notice the car holds on to the rpm's when I let off the throttle. could that cause an issue? I don't think there is a wiring issue as the car never acted up until after the lap top tune I had done. I know the tuner messed with the timing and air/fuel ratios
06-27-2010, 08:05 AM #6
Ive heard running rich can burn out o2 sensors, however im still running 2 stock o2 sensors on extensions and they arent burning out at all. Longtubes to a 3 inch x pipe with no mufflers and dumped and have yet to burn one out. When i had the x pipe put in they broke one but i replaced it and havent had a issue since. Dunno what to tell you but if all you have are headers and no cats it shouldnt be burning o2s out. I wouldnt throw the o2 sensors out that keep burning up, i hope your taking them back as "Defective". My advice if you did put headers in the car would be to get a tune, youve almost blown through 200-300 bucks as it is.
06-27-2010, 08:21 AM #7
06-27-2010, 08:44 AM #8
06-27-2010, 08:46 AM #9
06-27-2010, 10:25 AM #10
Other things that can make the car run rich: A real dirty air filter, an obstruction in the intake, a bad Engine Coolant Temperature (ECT) switch, excessive fuel pressure, leaking injectors, etc. Know anyone with a scan tool?
06-27-2010, 10:46 AM #11
06-27-2010, 11:01 AM #12
Which bank keeps going bad, is it bank one bank two or both?
06-27-2010, 11:17 AM #13
06-27-2010, 11:20 AM #14
You do know you dont have to reset the computer each time, its really not doing much for you at all, the lights still there you just have to travel 30 miles for it to cut back on and the system to completely reboot. So your light has to do with something other then your o2s. Bad wiring or something somewhere possibly also do you have your sensors from the rear still? If so swap those with the front ones assuming they werent bad and see if that does anything all the o2s in all 4 banks are the same. Further more if you can to pin down this problem more possibly, take pictures of where you put the o2 sensors in. Might not help me very much but someone else might see something wrong and be able to help with this problem more. Also when you had the o2s popped off did you have them kill the EGR as well? Lastly is the car running choppy or is it jerking at all when sitting at a stop?
06-27-2010, 11:25 AM #15
06-27-2010, 06:43 PM #16
- Apr 2008
- Madison, WI
what are the actual code numbers?
06-29-2010, 06:22 AM #17
- Mar 2010
- melbourne florida
Well the ses light went out on it's own and has stayed off for a full day now. Maybe the computer need time to adjust and get the proper readings from the new O2 sensors? I will keep you posted on how it's going.
06-29-2010, 12:35 PM #18
Its supposed to notice i think after 1 cycle if the fuel mix is off. But def keep us posted.
06-29-2010, 03:34 PM #19
It's possible for a bad or aftermarket MAF to cause a rich condition correct??
I've heard or read that even though you are actually running lean, the PCM could be overcompensating for a lean condition which would be sending too much fuel into the mix causing a rich condition.
06-30-2010, 04:43 AM #20
- Mar 2010
- melbourne florida
Another day and no ses light. Car is running noticably better. Performance is back and all is good. Thanks to all for the advice
O2 sensors
By c5z28 in forum Computer & TuningReplies: 27Last Post: 10-06-2010, 01:35 PM -
O2 sensors
By Soltakr in forum External EngineReplies: 19Last Post: 05-20-2008, 09:09 PM -
02 sensors
By 02sscamaro in forum General HelpReplies: 25Last Post: 04-16-2008, 04:02 AM -
o2 sensors
By ls1_02 in forum General HelpReplies: 9Last Post: 01-10-2008, 08:51 AM -
Should I buy new sensors?
By EastTNZ28 in forum General HelpReplies: 0Last Post: 06-15-2007, 09:14 PM
