Thread: Idle problem
06-26-2010, 07:18 PM #1
- Feb 2007
- austin
Black/Black- '00 Firebird WS6 T/A
Idle problem
Well, I say Idle problem. What happened is this: I took off the throttle body, to get the water pump out, then replaced the water pump. I stuffed some rags in the intake manifold because it got dark and the adhesive was going to need to sit overnight anyway. That was last night.
Tonight I put everything back together and started up the car - it ran fine, except idle was around 800 rpm instead of the usual 600. Also, upon driving, it tends to keep revving around the same amount with the gas depressed a little, or not. Before, it would slow down pretty quickly when you let go of the throttle.
To me, it seems like the throttle body may have just not gone back on right, because I reused the stock gasketing - maybe I need some permatex or something. I had to pull the EGR too though and it may not be in right. Just curious where I should start tomorrow. Damn it.
06-26-2010, 07:24 PM #2
- Feb 2007
- austin
Throttle doesn't feel sticky or anything and I cleaned it up pretty nice yesterday so I don't think that's it... should probably mention I think the TB and EGR went on well too. Hope I didn't crack the intake manifold or anything but it was overheating before I replaced the water pump and i guess it could have melted a little or something. AIR blockoff plate on the driver's side leaks a little and the underhood was kinda smoky when it was running earlier, nothing thick, but it seemed to come from the back of the engine bay. That's about all I think; hope somebody has an idea.
06-26-2010, 09:04 PM #3
- Feb 2007
- austin
checked the oil and coolant... isn't sucking coolant and there's no milk in the oil.
06-26-2010, 09:31 PM #4
- Feb 2007
- austin
it sounds like it may be sucking some extra in around the tb/egr connections... i'll try the egr first but i wanted to know if anyone's had anything like this happen before. may be a vacuum leak, the hose going to the tb is displaying a little cracking and may be causing that. 190k :O
06-27-2010, 06:53 AM #5
- Apr 2008
- Madison, WI
sounds like a small vacuum leak
06-27-2010, 08:20 AM #6
- Feb 2007
- austin
replaced bad-looking hose... also tightened EGR connection but still having the problem. definite sucking sound coming from EGR hookup - I think it may be time to get rid of it altogether. i'll try to pull it off and put it back on when i get home but if the damn car still won't run right i'm gonna junk it.
06-27-2010, 08:24 AM #7
- Jan 2009
- North Jersey
Have you tried spraying soapy water around the TB/EGR connections to verify the leaks?
06-27-2010, 04:14 PM #8
- Feb 2007
- austin
well i didn't do that but i pulled off the EGR about 20 mins ago, bent it so it was being torqued (1 screw design = teh retard...) 360 degrees instead of leaking. Now it idles right so I just need to fix the exhaust leaks (HEADER TIME!) and it'll be good to go
Thanks ya'll.
Help: Idle Problem!!!
By 00hawk109 in forum General HelpReplies: 7Last Post: 10-11-2011, 01:38 PM -
01 S-10 4.3l idle problem
By TwinTA in forum GM TrucksReplies: 5Last Post: 03-28-2009, 02:17 PM -
Question: different idle problem
By Brad(WS/Z0.6) in forum General HelpReplies: 16Last Post: 01-31-2009, 07:19 AM -
Idle Problem please help
By christrusler in forum General HelpReplies: 18Last Post: 01-25-2009, 07:16 AM -
idle problem
By occamaroz in forum General HelpReplies: 4Last Post: 06-17-2006, 09:00 AM
