    Oct 2009
    queens, ny
    2002 Camaro Z28
    Rear end cover leaking
    So my rear end cover is leaking. Should I just replace the gasket or should I put the TA Performance Rear end Girdle?
    I don't and won't have the money any time soon to replace the rear with a 12 bolt/9" so I have to figure out a way to preserve this one for the time being.....
    has the car been lifted using the rear? If you lift the car with the rear you have to be careful that your jack doesn't rest on that cover or it'll bend it causing a leak. If it's bent I'd say replace it with the cover.....if it's not bent then I'd just replace the gasket. Both jobs are pretty easy.
    Oct 2009
    queens, ny
    2002 Camaro Z28
    Hasn't been lifted by the rear that I know of. I'll most likely just get the gasket, red rtv and refill it. Thanks for the response
    Gasket and RTV like you said, I would think that would stop any leaking.
    Oct 2009
    queens, ny
    2002 Camaro Z28
    Okay from the search I did I found that people either use 75w90 or 75w140. What brand is normally used and what do people use to get the oil into the rear?
    I have a 2002 Camaro Z28 6 speed with 3.42's. I'm pretty sure this is the torsen unit, so that means I don't need the limited slip additive...correct?
    Marylandistan
    2001 Trans Am (sold)
    I use any dino 80/90 and one bottle GM limited slip additive. I don't use a gasket on the cover either, just a bead of black silicone around it.
    Member turyg ls1's Avatar
    Apr 2010
    Clewiston,Fl
    2002 camaro ss slp #2582
    I just change out my rear bearings and used 75w90 gear oil
    and on the cover just used black silicone no gasket
    and that turned out fine
    Apr 2010
    Clewiston,Fl
    oh and i did have 1 problem my passenger axle is no good
    Quote Originally Posted by johnnybz28 View Post
    75W90 is what you want.
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    Yes and no. The LSD additive is normally for clutch posi, but GM still recommends it for your torsen. It cures the "Rusty Screw" noise some torsen posi's make.
    Senior Member
    texas
    2000 formula
    posi additive or no.........it still has that rusty screw noise
    Marylandistan
    Quote Originally Posted by sjsingle1 View Post
    Nothing will get rid of that short of ditching the Torsen for an Auburn or Eaton.
  1. Differential Cover Leaking & bolts backing out Solved!!
    By 79Firebird_99TA in forum General Help
    Last Post: 06-16-2012, 02:35 PM
  2. Differential Cover Leaking .... bolts backing out
    Last Post: 10-22-2011, 02:30 PM
  3. Question: rear seals leaking
    By JayTA98 in forum Drivetrain
    Last Post: 05-03-2011, 05:43 PM
  4. Rear End Leaking
    By FasFlex in forum Drivetrain
    Last Post: 03-25-2010, 09:51 PM
  5. rear end Diff is leaking
    By voodoochi1d in forum Drivetrain
    Last Post: 08-28-2007, 01:02 PM
