10-19-2011, 01:24 PM #1
Differential Cover Leaking .... bolts backing out
Since I've done the transmission, converter and poly tranny mount, my diff cover bolts are backing themselves out. I'm sure this is due to vibration.
I'm going to go back to the rubber mount and some lock tight on the bolts as well. 2 are already completely gone.
Anyone had this experience? This is weird as hell. Also is the stock 10 bolt aluminum? I read somewhere that the torque is 22 ft/lbs. I am fearful of torquing it down that much. I think I may have already stripped a couple..... sigh.
10-19-2011, 01:52 PM #211 years of bangin gears
- Jan 2009
- North Jersey
I think the stock rear is iron or steel. I don't think it's aluminum. You might have just stripped the bolts and not the holes in the rear. If the holes are stripped, look for a Helicoil kit from your local parts store.
10-19-2011, 02:17 PM #3
10-19-2011, 06:55 PM #4
First I have heard of this issue. I installed the cover on my 12 bolt with a dab of adhesive black silicone on the threads and have had no issues. Use brake cleaner (carefully) and compressed air to clean the bolt holes thoroughly and also clean your bolts before reinstalling them to remove any oil. Then apply a drop or two of blue Loc-Tite to each bolt as recommended above.
10-20-2011, 04:39 AM #5O U 8 1 2
- Nov 1999
- over here...
i've never heard of this happening... going back to a rubber mount will not change anything for that problem...
10-20-2011, 04:47 AM #6
+3.. Also agree with Jeff about cleaning out the bolt holes..
Oil or lube, even left over sealant can cause issues with thinking a bolt is tight when really it may not be tightened enough..
Remember also if you use locktite, to only apply a small amount to the bolt threads only..
Applying it into the bolt holes can/may have the same effect as having debris or oil/sealant in the holes and may not tighten enough/properly..Last edited by Smittro; 10-20-2011 at 04:51 AM.
10-20-2011, 12:18 PM #7
Good info ... thanks all.
Turns out that it was not leaking again after torquing it down tight. It had rained and smelled and looked like a leak again. So we're good to go ... but I am going to do the blue loc-tite!!
10-22-2011, 02:30 PM #811 years of bangin gears
- Jan 2009
- North Jersey
Even if you smell gear oil, it doesn't necessarily mean the rear is leaking. It is the heat/pressure escaping through the vent. I did some reading on the rearend in my car because mine gives off the odor, but there is no leak. Apparently the rears are designed to vent the heat/pressure to atmosphere.
Fluid Leaking From Tube to Differential Joint?
By slade8200 in forum DrivetrainReplies: 0Last Post: 09-24-2014, 07:10 AM -
Differential Cover Leaking & bolts backing out Solved!!
By 79Firebird_99TA in forum General HelpReplies: 3Last Post: 06-16-2012, 02:35 PM -
For Sale: SLP/AAM Cooling Differential Cover
By '02 WS6 in forum Parts For Sale / TradeReplies: 4Last Post: 02-17-2012, 03:11 AM -
Ported Oil Pump, 10 Spokes w/Tires, Backing Plates, Rear Cover, lid, and tons more
By greatwhitess in forum Parts For Sale / TradeReplies: 4Last Post: 04-26-2007, 03:11 AM -
1995 Z28 differential cover?
By dkishton1486 in forum DrivetrainReplies: 2Last Post: 05-05-2006, 08:56 PM
