Results 1 to 2 of 2
06-14-2010, 10:14 AM #1
PCM Tables Values for Larger Fuel Injectors
I need to upgrade from stock to 38 to 40 lb/hr injectors (3 bar fuel pressure) which is same as 43.9 to 46.2 lb/hr at 4 bar fuel pressure of my 2000 LS1. I use LS1 Edit to tune my car and will need to change the injector flow rate and injector offset tables in the PCM. Would anyone be able to provide the table values for specific injectors in the size range I need. As we all know, the PCM must be tuned for the corresponding flow rate and offset of the specific fuel injectors installed for the car to perform optimally. thanks.
06-17-2010, 02:49 AM #2
This should help.
http://ls1tuningguide.com/tuninghelpfiles.php
DFCO fuel cutoff tables?
By Firebirdjones in forum Computer & TuningReplies: 5Last Post: 03-13-2012, 08:33 PM -
How do I know when larger fuel injectors are needed?
By Sam-SS in forum General HelpReplies: 22Last Post: 10-09-2011, 12:04 PM -
LS1 all yr fuel injectors, oe fuel rail, pump,more
By Frost in forum Parts For Sale / TradeReplies: 7Last Post: 04-27-2009, 02:26 PM -
Do I need larger fuel injectors?
By richwebb78 in forum Internal EngineReplies: 23Last Post: 12-26-2007, 02:13 PM -
smaller fuel injectors means more fuel?
By Ger-Fire in forum LT1Replies: 5Last Post: 10-12-2006, 03:06 PM
